If that is the case then your clutch cable is adjusted correctly and everything is operating as it should be. I don't see any problems except what you've already described and that is the reistance normally seen/felt.If I start the engine, elevate the back wheel, and pull the clutch, the motor ticks along nicely, but the back wheel does not move at all. I hope that goes some way to explain how the clutch is being operated correctly by the clutch lever.
My suggestion? Go ride you bike and enjoy it. I don't believe you have a problem
Greg,Tom, have you ever heard of a engine that would slide the tire with the clutch pulled as this one does?
Bearings okay in the rear tire ?
I have a couple bikes both with grubee 66cc 2 stroke motors, one rolls fine and the other has this problem you describe with the drag/friction when clutch lever is pulled in. Said motor has 3000 miles, a while ago I opened the left side where the bar and bearing are; well the bearing was smashed/crushed to 2/3 or 3/4 its original width... I found a slightly longer bar than the one that was in there and this alleviated the problem of drag. I didn't have a replacement bearing so that crushed one is still in there, it may come out with a thin magnet but I haven't a magnet to fit in there. I know they have them at harbor freight but funds are tight even for a $2.59 magnet as such for my tool bag! The bike has drag when clutch handle is pulled in and the button is pushed down to hold it in place, however if it is pulled in tight up against the handle, holding it by hand which gets tiring, it rolls easy Instead of holding it by hand one could wrap a small rope around it a few times... The other bike does not have this issue.
i've also had to adjust the cable numerous times because I found that pedaling with the drag and not having the clutch lever pulled tight against the handlebar, made the cable loosen up and drag was there even with clutch lever pulled all the way in. I replaced the cable to the same effect but the bike is better than the last few months now that I know to hold it in tight when I want to pedal. Running with original clutch pads.
You will have to separate the Crank and losen the clutch sping a little bit. It seems like it is a little bit to tight which will cause a stiff clutch lever. It sucks because you have to practically tear the whole motor down. I don't think you can get to it with a very small punch or something but you may be able to see it from were your cable connection is at the motor.Hi folks,
I've been riding my motor bicycle for a few months now, and while I really enjoy it, there's one thing which is bothering me. It's bothering me specifically because I don't see other people on these forums talking about it.
The problem is the freewheel while I'm pulling the clutch. It's awful.
I've ridden motorbikes for years, so I'm completely familiar with the HUGE difference between a neutral gear, and just holding the clutch in. That is, I expected significant resistance when I had the engine completely off, and the peg in the clutch lever. I *can* ride the bike 'without engine' in this manner, but it's a *lot* harder. Like a brake is constantly slightly on.
I know the first replies will probably be trying to establish whether my clutch is properly adjusted, so I want to pre-empt that and say that I've tried adjusting the clutch loads of times. I think I have it just about perfect now, but whatever I try (even ridiculously tight so that it's completely engaged even when not being pulled!), I still get this resistance.
Also, I can pull the clutch and have the engine idle perfectly while the bike is standing still.
As I said, I expected the bike to be a lot harder to pedal, because I'm turning a tight chain attached to a small sprocket in the engine, but the resistance *is* a little higher than I even expected, and I'm wondering whether this issue can be fixed since I've seen nobody else here comment on it. In fact, I read people saying things like:
Which is so totally different to my experience.
Can anyone offer any insight into this? Is your bike noticeably harder to pedal when you fully pull the clutch and aren't using the engine?
