Hey Everyone,
I am constantly tinkering with my first build - I can't seem to get it to run quite right. I am running a YD100 engine with an NT carb mounted to a Mongoose dirt bike. I've recently done some modifications but now my bike runs TERRIBLY. Can't even crack 5 mph on flat ground and the engine keeps spluttering and popping.
I previously got it working ok - my top speed was only around 20 mph and I had to peddle going uphill but other than that no issues. I wanted to give my bike a little more power so I changed the red plastic air filter for a "performance" filter like the one found at this link:
tinyurl.com
This actually made my bike have less power. At this point, I went back to the stock NT carb air filter but I didn't include the red cover. Wanting to give my back as much air as possible, I simply attached the spongey filter material using the supplied plastic bracket.
While I was working on my bike I made a few other changes. I had seen my rear sprocket wasn't aligned so I took the back tire off and realigned the sprocket. Additionally I was using an extra extra long offset intake but since I removed the bulky red plastic cover this wasn't necessary. I changed the intake to a standard offset intake. I had hoped this, combined with removing the red cover, would give my bike more power. However, as mentioned, it now runs terribly.
My theory is that somehow removing the red plastic cover has made my bike run way way too lean. Would adjusting the c clip in the carb to supply more fuel address the problem?
One other idea I have is this. I had to manually twist the little sprocket that connects to the clutch lever in order to remove the chain so I could realign my rear-wheel sprocket. This was EXTREMELY difficult. Could I have potentially damaged my clutch somehow? Would that cause a loss of power?
BBR Tuning Speed Carburetor Air Filter
If you're looking for more performance out of your carburetor, set your carb up with a BBR Tuning High Performance Air Filter. Compatible with the Speed Carburetor and NT Carburetor, this air filter will bring more air in to your carb, and in turn, wil
