No idea, Exo. But rest assured it didn't come from here. I'd check with your IP. Sounds like a local problem but we're innocent my friend.
I've been a member of this (& other) forums for many years, & over the years, we've seen many shifty vendors posting here using fake names to give fake testimonials slandering other vendors products just to sell more of their own parts!
So Roadrash, you'll have to forgive me when I say that I'm highly suspicious of a newbee member who's only been here 1 month & his only 7 posts on this entire forum are praising CR Machine & HD Lightning (who are known shifty business partners) & slandering their competitions products.
I have nothing to gain, & I firmly stand behind my test results of these other CDIs being equal to the HDL.
I'll be doing even more detailed testing (including actual riding tests) & posting the results (good or bad) here.
I've been using the Gasbike ~ Super Charge CDIs for several years; they're inexpensive & work very well.
https://www.gasbike.net/products/super-charge-cdi-for-48cc-66cc-80cc-high-performance-1
How how about with performance mods over time
I would go with a reed valve (& matching 3rd port with a windowed piston), Those Zeda/ MZ 65 expansion chambers are pretty good & also re- jet the carb.
I agree. I'm not a promotor , but the Fred head is still the fastest smoothest running one I've tried. 90% of any concerns head out there is a china knockoff. At least Fred lowered costs to be fair. I get 2 mph more speed out of the Fred head , however I will admit it's a higher compression model it's 5cc most knockoffs are 6 or 7 cc which is lower compression , but still better than stock. I have a gas bike cdi. I think it's the thunder ( bought it a couple years ago) it made a huge difference in power , and I've run it on every bike I've built with stock magneto , and oz magneto , and the zeda 12 volt magneto. Whoever couldn't get the bike to run probably wired it wrong. I doubt he plugged he lightning because it actually came with wiring instructions+that's why it ran first try. Not everyone is up to no good here. People praise what works for them. Thanks Venice for the testing. Me personally won't spend 60+ dollars on a cdi when one from gas bike works for under $25. If I could make my own black box I'd just buy a generic cr copycat coil on ebayFred is a stand up guy that runs a straight business.
Fred really has nothing to do with HD Lightning except that he sells them.
Calling CR Machine shifty is out of line.
Hi Norm, we missed you at the March 31st Grange race.This post was started back in 2015 & I've had the very same Super Charge CDI on my race bike for exactly 3 years now without it failing!!.
Seeing how this thread has been resurrected from the dead, I'll just add a little more info...
I use stock China CDI's on almost every bike I build; they have a faster timing advance than all the aftermarket CDIs , & they make almost every engine runs it's best.
When I build a "super fire breather' racing engine with a reed, high compression head & a real motorcycle expansion chamber pipe, I'll at least try to use the stock box first, & if it doesn't perform right, then I'll try a Super Charge to retard the timing a little bit, (which usually helps smooth it out & run cooler).
Here's a very interesting video that dyno tests a stock CDI against the new 'high peformance' - HD Lightning Strike CDI... It proves what I've been saying, (that the stock CDI actually makes more HP)!!
I have no horse in that race. BUT I will say that kind of testing, is not nearly as unbiased as his claims. I would say, run the test - run it by someone uninvolved AND have the person completely blind to which CDI is being tested. I'm not saying this to start or continue the battle, just at 60 years old and involved in all forms of research for 40 years, bias is real and everywhere.
There is a reason science uses double blind testing.
Rob rigged that video. Maybe even subconciously.
I am not saying he purposely rigged anything. But yes, even the delta HP may be within the margin of error.
As I stated. At the very least a person should not know which is which.
Wow. OK man. I was not criticizing you or your thread. I actually think this is a great thread. I actually commend you for bringing some of the claims down to earth. I do apologize for not being clear about that. I was commenting on the video, not you. If you think my comments are negative, then fine. It's the world as I see it.
