Remove the spark plug, with the clutch out, rotate the rear wheel and see if it's still makes the same sound.I went on a simple 7 mile ride to go and from right.........i my motor went dead it had gas my carb is set stock and i changed the spark plug ..........now it wont start at all it just makes this horrible screeching noise like bad breaks on a car
Hopefully it's just a blown head gasket.. pull the head.A white colored spark plug is a sure sign of a lean mixture. The state of tune on the carburetor is not supplying enough fuel to the intake air charge. A lean mixture will destroy an engine given enough time. Tear down the top end and take a look at the cylinder and piston. Norm has shared a guide with us on how to do that if you want or need guidance.
http://motorbicycling.com/f39/bicycle-engine-tear-down-391.html
Depending on what you find, it may be much cheaper for you to just replace the top end rather than get a whole new kit.
You can make your own, but I don't. I keep spares around. Most engines come with 2 and I use one. Please don't forget to mill your head before you install a new head gasket. Milling the head, copper kote on gasket and proper torque solves these blown gaskets. I blew a head gasket on my first build...never again with the above.i pulled the head today and the gasket was warped bad causing a leak ......right
but i dont have a replacement gasket.......can i make my own?
It may work, but RTV is not the item to be used. The only thing that I'd ever use on a non coated metal gasket is Copper Cote or Permatex 80697. They sell it in auto stores..I buy it in the spray can.ok heres what i did and im freaked if i messed up.......i sanded the head right but i sanded the ring that meets the bottom and creats a cirlce like indent is the gasket.......i did this to make the two set flat on each other and they do......
after i did that i made a new gasket of the can lol......and sealed it on both sides with rtv for extra protection ..........hows this so far or do i have to buy a new head?
I feel that (if it is a 8mm stud) that 110 inch pounds is kind of light. Of course I replace all hardware with 8.8 metric (grade 5 USS) as my cylinder studs with lock nuts, 8 mm will take as high as 204 inch pounds (17 foot pounds), I use 150 the first time and 175 if I ever need to go into it again, which I haven't. I use Copper Cote, but in the past have aluminum paint as well, on the old chevy heads. The last engine that I bought and just got the parts in yesterday were 8x1.0 studs and not the 8x1.25.Now you can take the head off again and scrape off ALL of that RTV product.
Gasket sealers have their place but only those made for sealing a cylinder head should be used.
Plain old silver paint(not spray) will work better than most things. Paint it on heavy and let it dry slightly before assembling. Use a torque wrench, tighten to 110 inch pounds.
If you're using those chrome acorn nuts make sure they are not bottoming out before they are tight against the head. Preferably you should toss them and replace with shouldered hex nuts. The acorns are pretty but can be a source of problems.
I've never had one leak @110, Al and you have to keep in mind that regardless of the stud/bolt hardness you're still threading into an aluminum casting on the bottom side.I feel that (if it is a 8mm stud) that 110 inch pounds is kind of light. Of course I replace all hardware with 8.8 metric (grade 5 USS) as my cylinder studs with lock nuts, 8 mm will take as high as 204 inch pounds (17 foot pounds), I use 150 the first time and 175 if I ever need to go into it again, which I haven't. I use Copper Cote, but in the past have aluminum paint as well, on the old chevy heads. The last engine that I bought and just got the parts in yesterday were 8x1.0 studs and not the 8x1.25.
