Metal throttle grip mount?
Discussion in 'Motorized Bicycle General Discussion' started by Allen_Wrench, Dec 29, 2010.
  1. DaveC
    DaveC Member
    Jul 14, 2010
    970
    The metal handle is on the third page of two stroke parts.
    Sick Bike Parts
    Here ya go. I buy a lot of parts from SBP and I'll be buying a lot more :)
  2. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    how did you guys make the napa throttle work? i got one today switching the cable over from my CNS carb+kit throttle has been a nightmare, the L shaped piece isn't able to fit into the napa throttle so my cables binding, and on top of that i can't get the throttle to stay in place even though i have it tightened down as much as possible.
  3. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    Some times there are little areas of overcast that you have to file off . I have also used a shim made from a strip of beer can. To beef up the bar a few mm.
  4. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
  5. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    i ended up taking it to a scooter shop and the guy who helped me modify my cable to make it work yesterday helped me get it straightened out, ground down those edges for it to be smoother, and put a little rubber tape stuff to help the throttle stay in place.
    gonna get a self tapping screw and just drill into the handlebars and that will keep the throttle in place.
    and he offered me a temp. job helping around his shop and if i can be useful i'll have a more permanent one, good day :D
  6. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    Wow thats great ,got your bike running and a job , if you took a nap that day it may have been perfect;)
  7. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    this was today, just finished putting the self tapping screw in place, rode around and got some tacos.
    still got time to take a nap :)
  8. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    I keep trying to tell people about the power of napping,one of my fav things to do is ride about ten miles out to a local forest pers. Down a tallboy and nap on a picknic table. Sometimes people even feed you if they want a look at the bike...but ride,tacos ,nap sounds right enough.
  9. Allen_Wrench
    Feb 6, 2010
    2,787
    You know that L-shaped piece, well it wasn't a problem for me - but only because I knew going in that I had a thread cutter and dies. I just cut new threads on the L-shaped sleave that matched the NAPA throttle mount. I just happen to have that kind of tool already,
    (Now he's thinking of new names to call me.)
  10. matthurd
    matthurd New Member
    Dec 13, 2010
    817
    i had thought of that but it seemed like a lot of metal to take off, in the end i ditched that piece entirely, soldering is simpler then rethreading an 1/8inch of metal off to me.
  11. Goat Herder
    Apr 28, 2008
    6,251
    I did the same thing with my metal throttle listed in this thread. I did a slight modification to the cable channel where my soldered cable end would go too and its been great.
    Glade to see you got it going Mat and scored work too !!!
  12. hotbug1776
    hotbug1776 New Member
    Apr 7, 2011
    49
    In regards to modifying the "L" on the cable, what size die did you use? I'm planning on modifying my cable and am going to purchase the needed tools this week.
  13. Goat Herder
    Apr 28, 2008
    6,251
  14. Allen_Wrench
    Feb 6, 2010
    2,787
    I'd have to go out to the shed and look. I hope it's the same one that's still mounted in the handle (should be). Dang nab it! And I knew somebody would ask.
    Checking back. Went out there and, oops, nothing in there. I usually just leave the die in there after I cut threads, but for some reason, this time I took it out. I suppose I could unscrew the throttle mount and check. Or, if you don't want to wait on me doing that, just take the mount with you when you go to buy tools. Most hardware stores have little nut-and-bolt gauges on the wall near the nuts and bolts. Just screw it onto a bolt end that fits. That'll give you the sze and pitch you need.
    #34 Allen_Wrench, May 18, 2011
  15. hotbug1776
    Apr 7, 2011
    49
    9mmx1.25
    cut it and installed right after work, ready to ride once I get the ignition wiring redone and the sun pokes out from behind the storm clouds.
