Okay so I am a newbie and I humbly admit it. However I have learned a few things so far and am trying new things regularly. I will post here as I learn whether they work or not.
Tip #1 and foremost is immediately take out that junk chinese spark plug and put in an NGK Iridium 4085 {also know as the NGK BPR6HIX}. They are hard to find and you might have to special order it in but go, go now and get one. They are a bit more expensive than normal plugs but oh so worth it. {anywhere from $6-00 to $15-00 depending where you get/order it from}. It made my engine way smoother, more powerful throughout, and added about 5 mph on to my top speed! Next I am going to put on a new plug wire and see what that does.
Tip #2 is the clutch cover. I have noticed that there is all sorts of sound dampening products out there to buy but I just took some left over silicone gasket caulking, cleaned the inside of the cover off and smeared the inside of the cover with the caulking. {I gently put it back a few times to get the right thickness so as not to smear it on too thick} I then let it dry overnight, then put it back on. Way way quieter, cheap and easy! {Before putting cover back on it is a good idea to put a bunch of good quality grease on the gears}
Tip #3 Now that we have a frame mount engine where the heck do I put my water bottle??? Find an old inner tube and a few hose clamps. Take your hose clamps and put them around your forks, wrap the fork where you are going to attach the cage with the inner tube and tighten the hose clamps!
I have done this to both front forks and now have a water bottle and a spare fuel bottle {use something like an MSR fuel bottle not a water bottle for the fuel}. I have further zip tied the top of the fuel bottle to the fork just to make it extra secure. I have gone both on street and off road and have had no problems with them getting lost or loosening. Mind you if you use a $2-00 H2O cage you get what you pay for.
Tip #4 Port your exhaust and intake. Even a small amount makes a difference.
Tip #5 This will not apply to all, but to who it applies to it makes a huge difference. The 66cc chinese lady I was given was several years old and had the stock muffler with no heat shield. I took the small nut off the bottom and took it apart. I then drilled 4 holes (about 1/4 inch) just before the catalytic converter. I probably tripled the power of my motor. I presume that my catalytic converter was badly clogged. I am a bit noisier now but not too bad, but wow talk about more power.
Tip #6 Tighten everything and then regularly check and tighten everything especially the head bolts! {Mind you be very careful not to over-tighten!!!} Thread lock compound can be your best friend! {http://www.loctiteproducts.com/threadlockers.shtml}
So far though with just what I have listed I have managed to get {on the flat and level with no wind} 52 km/h {32.3 mph}. I just took a 40 mile trip on it with no problems at all. On the highway though I usually cruise at 40 km/h {25 mph}. I am 200 lbs and this is a cheap old bike I have it installed on so your results might vary.
I have an expansion muffler and a smaller gear ordered and should be in within a few days. I will let you know more when I get them installed.
I also have a few more tips and tricks that I am going to try.
As I said though, I am a newbie. I am about to start my second build {a 4 stroke pusher}. I make no guarantees but what I will be posting here has worked for me {or if I try some lemons I will post them also.
If there is any real experts out there and I post anything too dumb please feel free to comment.
If anyone has any questions please post or pm me.
