M.T.
Hope the repair goes well and most of all inexpensively. Thank you for the tip about loctite. I'll get some and ask the machinist to put it on the bearings before he assembles them.
Steve.
Thanks.
I should note that different stuff I also prior had bought, anti-seize compound is not compatible with the bearing mount compound. If I used both, I have to be sure I could assemble without having to slide anything going on the jack-shaft where contamination would occur.
I'd say it best to use the bearing mount compound first and then if the anti-seize can be added last that would suffice. Otherwise I would go without anti-seize.
And here is the caveat, how to disassemble bearings from jack-shaft. They say on the package may take 500F degree heat and or gear puller. If this is not an option then don't use this stuff. The kind of sealed bearings with that rubber seals I use would be a mess with heat I imagine.
Found this thread even though it is about the other brand Permatex:
http://forum.ih8mud.com/threads/wheel-bearing-races-secured-with-permatex-bearing-mount.677315/
Info on Loctite although the newer stick is not shown liquid is similar. The directions on the package for Loctite Bearing Mount Stick say to use Loctite Klean an Prime.
I already have the primer for other Loctite products I have. Interestingly the pdf file below mentions that for greater strength to not use the primer and to let cure longer 4-24 hrs. I think in my situation I can use the primer and have it cure quicker and have a bit less strength so disassembling will be less a problem.
Checked and I can remove the bolts holding the bearing mounts and take the whole jackshaft over to a workbench where gear puller could be used. If necessary heat far away from gas tank and engine. There is no room otherwise on how I designed my bike.
Those hardcore's in the thread above had a concern for off-roading and having the available tools to use on the breakdown spot. As long as I get back to camp I have my folding work bench. I have extra bearings I bought and would have them with me.
I wondered about one spec it says for this stuff:
Military Specification
Canadian Food Inspection Agency (CFIA)
I checked yea, maybe you can use the tri-car to setup with a bailer. Figure on a way to automate for hops clean and kilning and leave the bines in the field not done yet.
Old time movie hops harvest:
https://www.youtube.com/watch?v=V44cH1s9kzE
MT
