Poopyboogin420
pulled the magneto apart and cleaned it with some sandpaper today. there really isn't much to a magneto, so I don't see how it could go bad.
I cleaned the connections to the wires, and I cleaned the top of the plug.
Thats good...
I tried running alongside the bike (with the plug hanging from the coil wire and resting atop the motor) and when I dumped the clutch the motor spun over fine, but still no fire.
I closed the gap on the plug about halfway, and still nothing.
Did you use a gauge? should be .025-.030. I did mine at a few spots to find where the engine ran the best, I think .028 was where I ended up.
Where to now? I hate to simply start replacing parts on a brand new kit. I know they're not expensive...but I mean it's brand new, it should work.
I hope I've got everything hooked up right, it shouldn't be too complicated. I've got the black wire hooked to the black on the coil and the blue wire hooked to the blue on the magneto. That's it. It's an extremely simple system, I don't see where my wiring could be at fault.
You're on the right track, something is just not working, and I'm pretty sure its the ignition system. I'm starting to think it might be a bad CDI. Another member had the same problem as you(minus the rusty mag) and it turned out to be a bad CDI.
And that's it right? The magneto spins and the coil fires? right?
do you have to get going crazy fast before it works or something?
Shouldn't have go crazy fast, about 7 MPH or so... I hate to say it but I think you might need to replace the CDI, where did you get your kit? Whoever you bought it from might be able to replace it. Otherwise you should only be out $20, $25 or so. I know what you mean about buying new parts. Believe me. My motor just died on me after about 600 miles because there was metal shavings left over in the engine that ended up gouging my cylinder wall and causing me to lose compression.
Even at that, I am still going to only shell out $50 to fix it, and this time I will flush the engine out before running it. They are cheap, and you have to expect some parts to be bad from the get go.
