front tire
Discussion in 'Motorized Bicycle General Discussion' started by KarenH, Nov 5, 2014.
  1. KarenH
    KarenH New Member
    Sep 21, 2014
    55
    OMG, I can't get front tire off. It has one of those quick releases but it isn't releasing lol. I freed the front brake and I pulled the lever open for the quick release on the tire, but the tire still won't slip off.
  2. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    The ends of the quick release will 'unscrew' if you just try... & then there might be safety washers under them that lock the axle onto the fork... simply pull them both outward.
  3. kevyleven007
    kevyleven007 Active Member
    Sep 25, 2008
    1,206
    uh oh. Did you try to loosen the nut on the other side of the quick release? Sounds like you might have to take it to a shop then. You might want to check out some basic repair vids on U-tube.
    #3 kevyleven007, Nov 5, 2014
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,771
    88
    it has 'lawyer lips' on the forks (google it) - you'll need to get the axle way loose to get it off - some folks grind those off the forks once the wheel is out of the way
  5. KarenH
    KarenH New Member
    Sep 21, 2014
    55
    Thanks everyone. I will research it further. U did "unscrew" the quick release after opening it and loosened the nut on the other side, but the wheel still won't drop out. I can't figure out what is hanging it up.
  6. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    Hit it harder. Lmfao
  7. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    I believe the fork is designed to hold the ends in place- try separating the fork ends with your hands only- they need to clear , and then will drop down
    if that isn't it, perhaps someone tightened some thin axle nuts- that usually go between the fork blades, on the outside of them.
  8. kevyleven007
    Sep 25, 2008
    1,206
    You should be able to unscrew the nut and pull the quick release skewer completely out. Then grab the fork ends and pull them apart.
  9. scotto-
    Jun 3, 2010
    6,530
    6
    A small charge of C-4 plastic explosive ought to loosen it up if nothing else works :D
  10. KarenH
    KarenH New Member
    Sep 21, 2014
    55
    Thanks everyone I will try everything except maybe for the C4! ROFL
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    LOL, never say never...
  12. KarenH
    KarenH New Member
    Sep 21, 2014
    55
    I did finally get it off.
  13. Intrepid Wheelwoman
    Intrepid Wheelwoman New Member
    Oct 29, 2011
    2,831
