For Old Guys Only
Tom I rewired it one wire at a time from start to finish with the help of my son, he asked me why I didn't just pull the old harness out and start over I told him that there was no one around that wired one of these and if there was he couldn't not remember how! I changed from 6v positive ground to 12v negative, changed from generator to alternator. Changed coil, solenoid, and all bulbs. Replaced the vacuum wiper motor with a 2 speed electric. It runs great, the 6v starter has worked well so far. Tom I can get both pumps new not rebuilt for $160.
I'm kinda ashamed of the delco alternator on a ford, I'm thinking of changing to a 60's ford alt with a external regulator. The delco was just easier and are plentiful. I have it tore down starting body work, the picture below is how it is right now.
Flat head Ford V8 you are a lucky guy. If you don't have one with a cracked block. When you convert from 6volts to 12volts system make sure you install a resistor on the hot wire from the coil to the distributor. If you don't you'll smoke the points. Removing the distributor from in front of the radiator can be a lot of fun. If I remember right they have 2 sets of points, the point gap and dwell have got to be right on or you will not run right. Make sure to check your water pumps they are prone to leak.
buzzard
Good advice Buzzard, that's what ive done. Mine has single points, I also replaced the condenser with that of a 60s 12v model. It starts right up and runs like a champ. I don't like the resistor much so I'm going to change to a internal resistor coil, it'll look better I think.
One good thing about being an old guy is that you get to see how well things stand the test of time. I had this lock on my locker in high school. The lock is now over 40 years old. It has spent the last 25 years on my shed, outdoors. I have held it upside-down and shaken the water out of it several times. It gets regular maintenance. I spray it with penetrating oil once every 10 years. An other good thing is that I don't have to memorize a new combination. What reliable old things do you still have. No “old ladies” please. Unfortunately that is an other old guy thing in the background. …. D.J.
I have some elderly guitar amps I picked up along the way, and a converted hi fi amp that's at least 46 years old. It sings with a voice like 1950s Chicago.
When I moved Pops out here with me I took as much as I could fit in the car. Pity really, I left a lot of great stuff back there as I have a house full of stuff here and there was no room.
Here a favorite;
Old Craftsman hand drill. For light work like holes for drywall anchors, there is no easier or faster tool.
Here's mine Mike.
"Yankee" No. 30A, North Bros. MFG. CO., PHILA. PA. U.S.A., Pat 11. 23.
It's got forward and reverse, but you have to notch the bits to suit the internal locking mechanism. I intend to use it for fine work, if I ever do any!
It works like a buffing belt and polishes the axel. a weight like a relfector or rivet that holds it on also slows it making it spin slower then the axel. Plus it keeps the rust and grease off. I used to see shinny hubs and rusty spokes.
Give this guy a cigar, that's exactly what they do. I can't remember seeing any since I was kid. That was back when dirt was still being made.
Found something laying around that might interest some... center cap, I believe.
Here a favorite;
I've never heard of one going flat either.
Here a favorite;
No electricity no battery no problm!
Here a favorite;
Got one of these and a Brace & Bits. A Lithium Ion drill is a fantastic thing, but when it runs down I'm usually not done working. So I grab the old stuff while the new stuff charges. Got an old reel-type push mower too. I tell people it runs on coffee. My brother even has a hand-cranked drill press.
.trk
Somewhere I saw a reel-type mower with a hot rodded Happytime engine on it. It was inspiring.
images
https://encrypted-tbn2.gstatic.com/...eouh1Zz4rspYUNsXTomthY5xdF0iAxqYVZ-8BgW3gKe-A commercially made bicycle lawnmower pedal powered
My bicycle drawn gas powered hiking trail and lawn mower
still in the works. I got a free mower yesterday, think I will put the engine on the bike trailer (took off my good one for the regular mower)
http://www.youtube.com/watch?v=EZaFe545r0E
