Fail
Discussion in 'Motorized Bicycle General Discussion' started by Aric, Aug 14, 2013.
  1. Aric
    Aric New Member
    Aug 8, 2013
    54
    well i got my eninge kit on time as expected . but the bike i bought for it the frames too small......fjweiuhfiuweuf "pulling my hair out right now" spark plug is way to close to the top tube especially when the uni mount is on there due to the frame being a centimeter too wide... anyone know of a specific bike that will work preferably hard tail mountain bike
  2. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
    Spark plug too close to frame? If it's at an angle to the piston and pointing backwards, you can turn the head 180-degrees so the spark-plug points towards to the front of the bike. Might give you enough room. Give is more details! Engine type? Bike model?
  3. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    Hello Aric, their is also shorter spark plugs that you can use that may give you the clearance you need?
  4. Aric
    Aric New Member
    Aug 8, 2013
    54
    i just bought the angle fire 66 cc flying horse engine an im putting it on an older diamondback wildwood full rigid no suspension bike
  5. Aric
    Aric New Member
    Aug 8, 2013
    54
    wow if its just that simple to turn it around that would probably fit it perfect
  6. Aric
    Aric New Member
    Aug 8, 2013
    54
    wow i feel so dumb.... that was the easiest thing to do an to think i was going to buy another damn bike.....
  7. scotto-
    Jun 3, 2010
    6,530
    6
    Problem solved.....Pass....no Fail!
  8. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,077
    It always help to post pics when there an issue that needs to be resolved . And to answer your question the easiest frame to put an engine and it's some kind of a beach cruiser.
  9. MotorBicycleRacing
    Jul 28, 2010
    5,738
    40
    Did you use a torque wrench to tighten your head bolts?
  10. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    Good job Aric.
    We all have those moments, and trust me, there will be more of them. :)
    Welcome to the forum.
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    Ayup, what Dodge Dude said! All the really great and experienced builders have some great stories about such stuff.
    Cool part about it is you probably saved some one else from going out and getting another bike.
    Looking forward to seeing your build Aric.
    “I have not failed. I've just found 10,000 ways that won't work.”
    Thomas A. Edison (LOL, kinda my mantra)
  12. Aric
    Aric New Member
    Aug 8, 2013
    54
    no an i dont own one i used a ratchet what will happen if a torque wrench is not used ?
  13. Aric
    Aric New Member
    Aug 8, 2013
    54
    fyi im an idiot when it comes to these things this is my first mechanical build ever
  14. MotorBicycleRacing
    Jul 28, 2010
    5,738
    40
    tighten too much and pull a head stud out.
    not tighten enough or unevenly and your head gasket will leak.
    Pro mechanics use torque wrenches. :)
  15. Pilotgeek
    Pilotgeek New Member
    Apr 6, 2011
    403
    I lived without a torque wrench for a while. Just make sure all the head bolts are tightened evenly, and make them nice and snug without feeling like they're too tight.
  16. Aric
    Aric New Member
    Aug 8, 2013
    54
    hehe :) i tightened them all evenly an not to much so if it leaks ill run out an get one hahaha ima noob
  17. Aric
    Aric New Member
    Aug 8, 2013
    54
    phew i thought i just destroyed this thing... i am having problem installing the clutch clip i dont get how it goes on haha
    motor is mounted clutch handle is set up along with throttle
  18. Aric
    Aric New Member
    Aug 8, 2013
    54
    will say i love doing this 12 hours my womans gone something about putting this together is stimulating mah brain
  19. dodge dude94
    Jun 8, 2012
    1,017
    I didn't use a torque wrench for most of the time I've owned this bike. lmao
    Tighten in an x-pattern, then go a 1/4 turn past tight-ish.
  20. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    Know what you mean. I enjoy the tinkering/building as much as the ridding.
