If you look at a new cylinder you'll see the cross hone is very fine. Not coarse like old motors were. You have a very limited time to get the rings to seat properly. You do need to run it for 3-5 minutes then off till it cools all the way. (bout a half hour) Do that twice to let the bearings seat. I replaced my entire top end after about 2000 miles because the pin in the ring groove came out and gouged the cylinder. I broke in the new top end as fast and as hard as I could with keeping track of it not getting to hot. This top end has more compression and the motor has better power and more top end speed than the old top end ever had. I also broke it in with opti-2 at 75/1 from start up this time. Not with 16/1 regular 2-stroke oil. I pulled the head the other day cause I blew the head gasket (see general discussion for pics, actual blown head gasket) The new cylinder is smooth as silk and my motor runs better than it ever has. I have a shift kit, tuned pipe, CNS carb. I can do 42mph on a flat road with no wind paced by a new car. Not checked with a bike speedo. I know everyone has different ideas on this. This is what is working for me.
