Completely new... Help?
Discussion in 'Motorized Bicycle General Discussion' started by cartersummerell, Dec 11, 2011.
  1. cartersummerell
    cartersummerell New Member
    Dec 11, 2011
    9
    Hello,
    Im totally new to the forum and also the idea of a motorized bicycle. I would like to build one but I have certain questions....
    1- will I be able to go up hills?
    2- whats the fastest these things go?
    3- why are pedals still on the bikes?
    4- whats the easiest engine to "cannibalize" ?
    5- do people use gears (from a mountain bike or something)?
    Thanks! Im excited for this haha
    -Carter
  2. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    read every section on this forum and all the posts in them
    then you will have your answers
    as far as pedals ....... a BICYCLE has pedals a motorcycle does not
  3. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    Welcome to the club, Carter.
    All of your questions will be answered when you do more research on what you're interested in.
  4. cartersummerell
    Dec 11, 2011
    9
    I have looked all over the forums and read alot, but my first questions are these...
    What are the advantages to running a 2 stroke compared to a 4?
    I know that the 2 stroke gets a little bit faster but the 4 stroke can sustain an alright speed for a long time.
    as far as my questions about the gears, still stands...
    and same with the pedals. but I want to build something like a board tracker, im just not sure where to start or what frame...
  5. cartersummerell
    Dec 11, 2011
    9
    also do chainsaw engines work well?
  6. Venice Motor Bikes
    Mar 20, 2008
    6,216
    25
    It's been proven that the 2-strokes can run at full throttle all day long. ;)
  7. kolomootro
    kolomootro New Member
    May 24, 2011
    62
    1 yes you will probobly be able to go up hills with chinese kits with 44 t sprocket the kits come with.
    2 depends, kits should go 30 more or less.
    3you have to start the engine with pedals or if your engine has a pull rope its still nice to have your feet not dangling.
    4.idk i havnt really tried
    5 yes they sell shift kits but they cost money.
    4 stroke you dont have to mix oil 2 stroke you do.
    if your not gonna use kit then it all depends.
    #7 kolomootro, Dec 11, 2011
  8. yodar
    yodar New Member
    Jul 26, 2010
    147
    see my italicized inserts following your questions
    contact me off list for PDF copies of assembly instructions I have filed away
    cz52_99[email protected]
    yodar
  9. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    2 stroke Vs. 4 cycle-
    Personally the more I've used the China Girl 2 strokes, the more I like em for a bicycle motor-
    1. Cheaper initial cost and parts
    2. They fit between most pedals- have to go wider crank for a heavier 4 stroke that carries oil internally and needs valves beside the head.
    3. on the negative, they are a little noisier I think, but noise can be minimized
    4. 2 strokes need less "power conversion" apparatus. If you planned to use a shift kit to take advantage of the bicycle gears with the motor, this might equal out some, but you can run a chain straight from the 2 stroke to the back wheel gear, no fuss no muss.
    I have a scooter, with 16" moped size wheels even, but I find my motorized bicycle so much more convenient to use, and part of that is that I like to cut the power and pedal around. after a long racing career I keep the seat up at normal peddling height and have narrow 700 C and 27" tires so that I have a fairly viable peddling bicycle otherwise- and it rolls and rolls for blocks after I cut the motor off.
    Being in Florida too you'll probably have no problems with the authorities, but please don't be a maniac. as to your query about speed, when you really go at it and if you want to use a bike for practical transportation, you may find that a decent cruising speed is more what you're after as opposed to the top end- The little motors scream quite a bit wide open- With some bigger gearing (that means smaller sprocket in the back) you can be at 25 or 30 without opening the motor up full and taxing it so- it's your motor and you don't want to repair it all the time right?
    I've had good results with a 36 on a 66 motor, but a 50cc handles a 39 pretty well and still moves along nicely, with a lighter and quieter, but obviously less powerful motor. See my sound comparison video in the video threads
    If it were me, and unless you're a super motor mechanic, I'd start out simple and stay to a beaten kit path whether 2 or 4 stroke- I've paid more attention to the bike itself although I do have two builds with both sizes of China Girl 2 strokers- Wheels that roll and tires that don't vibrate like beach tires do are big fators for me- I use shock seat posts and have a shock fork on the faster bike.
    I like to use alloy BMX bars with a slight rise for my bad back but most importantly that have a solid perpenicular grip on them- ya gotta hang on!
    A billet intake really helps the motor perform as intended as does a newer 66 speed carb when using a newer 66 motor.
    My bikes are lightweight so I can push them up and down a flight of apartment stairs, but I wouldn't have the any other way- that's why I like three piece alloy crank conversions and the alloy bars and stems, and always alloy rims for the relatively smooth Florida streets.
    A 415 TRIKE chain weighs little more than half the standard kit chain, although the same width, and really rolls quietly- a real difference peddling too..santa(^)
    #9 Nashville Kat, Dec 11, 2011
  10. Rocky_Motor
    Rocky_Motor New Member
    Nov 14, 2011
    367
    That looks real nice! Except your rear brake. That looks rather frightening D:
    My goal for my bike is to make it very peddleable too. Finals week though... Can't work on the bike for a bit.. )=
  11. Venice Motor Bikes
    Mar 20, 2008
    6,216
    25
    The pedals are nessesary because the engines aren't very powerful & you still have to pedal the bike to get it rolling (& help it get up to speed); & also, if you remove the pedals, it's no longer a motorized bicycle... it's now a scooter & falls into a whole different catagory with the law.
  12. cartersummerell
    Dec 11, 2011
    9
    Thanks guys! thats really helpful. I keep yall updated on my decisions!
    Thanks for everything guys
  13. Allen_Wrench
    Feb 6, 2010
    2,787
    I know I'm late to chime in, but I thought there might still be room to contribute.
    - Re hills: how well your bike takes hills depends on 1) how you've geared the rear wheel, and 2) how powerful your engine actually is. For example, I have a 2-stroke HT that has been port matched and the carburettor has been tweaked and messed with. I run a 38T rear sprocket and I climb modest hills like they're not there, and some steeper ones - I just give her more gas.
    - Re engines: that is very much a matter of personal preference. Go with what you know best and would rather have. If you're more comfortable working on 4-strokes, those may be easier for you. I find 2-strokes easier myself, but I can't say I've ever HAD to work on mine. I've done the usual "dialing in", changed a plug, etc. But mine's so durned reliable I've never needed to do any emergency stuff. Truthfully: my bike is more reliable than my Dodge Caravan, and that says a lot to me. Whichever you choose, you will find experienced help, support, and boatloads of knowledge here on this forum.
    - Re helmets: I wasn't going to preach, really I wasn't. I just saw it wasn't mentioned and thought I'd bring it up. If you were to ask me, I would tell you I believe they work. There are conditions and circumstances where a helmet will save your life. But remember: it is, and always will be, your choice. If you choose one, get a good one - DOT certified at least. If not, hey, what can we say? You're an adult. You're entitled.
    #13 Allen_Wrench, Dec 11, 2011
