This is my second CVT that I have purchased and will be using on my newest build "Custom Frame for Board Track Thumper". The drawback of the CVT is you have to off-set the motor to get the drive chain to line up, if you don't mount your motor just right the alignment will be off with no adjustment.
The modification moves the drive gear to the opposite side of the plate which allows you to center the motor and have adjustment for the correct alignment. The gear can slide back and forth with ease. I have had this idea for awhile and decided this build would be the perfect time to try it. Plus ya gota love the way a CVT works...
