Break in secrets
Discussion in 'Motorized Bicycle General Discussion' started by wayne z, Dec 25, 2010.
  1. Predator303
    Predator303 New Member
    Apr 26, 2012
    648
    Very interesting. I will break in the GT5 I bought yesterday in a couple of days and one thing I know for sure. No way in **** I will give a new engine high rpm but full throttle in low and mid range rpm should work fine. I used to build turbo engines in Europe with extreme pressure and compared to that the china motors are extremely simple but its still impressive of the power that little piston can generate. Hopefully I get a good engine.
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    I wouldn't add WOT at low RPM.
  3. Predator303
    Apr 26, 2012
    648
    Above 2.500 not extremely low
  4. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    You need a fairly steady load to keep the new piston rings from chattering until they wear mate in. This gos back to the old argument of folks not babying their motors of all origins and having good strong running motors later on.
    I climb a 4 to 5 mile up hill run on all my first start ups and vary my throttle except for a full on high speed run. Just that I like to have that steady load. Then in my mind, from my concept approach rings never chattered like they would have been prone to do otherwise..
    Just letting a engine rev or idle in the drive way as a approach to a healthy break in is the absolute worst thing one can do. Their is no load and just chattering going on then
    After a period of break in i run it any way I wanna.
  5. Predator303
    Apr 26, 2012
    648
    dont have any hills near me. i live right at the beach. all flat here more or less but great for small sprockets.
  6. Goat Herder
    Apr 28, 2008
    6,251
    While I do use the hills I have near me. I like to use that analogy to make my point just because I feel it draws a nice picture of what i meant to conjure.
  7. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    Full throttle and low to mid rpm is the best way to seat the rings quickly, before the crosshatch hone marks smooth down. This forces the rings hard against the bore for quick and good seating of the rings to the bore.
    On all my new trucks, engines or rebuilds, and I have had many, I use full throttle to load the rings as soon as the engine is slightly warmed up on the first start.
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    That's with a pressure lube system.
    High load at very low rpm is a little rough on the bottom end.
    That sounded weird. LOL!
  9. Allen_Wrench
    Feb 6, 2010
    2,787
    Yeah, I've heard it can get kinda rough if there's no lube at the bottom end. Now, is that just with a heavy load?
  10. Predator303
    Apr 26, 2012
    648
    Could anybody tell me a trick to measure 25:1 for breaking in a 2 stroke with 1,5 liter gas? I dont have any measure cups or anything.
    Also. I keep reading NOT to use synthetic oil for breaking in the engine. I got Shell Nautilus non synthetic oil here. Should I use that or get synthetic?
    Thank you
  11. Bikeguy Joe
    Jan 8, 2008
    11,529
    If that's marine (outboard) oil, don't use it regardless of whether its synthetic or not.
    I think you can google gasoline ratio calculator.
  12. Predator303
    Apr 26, 2012
    648
    No its not for outboards. I bought it at the gas station.
  13. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    shell nautilus is outboard engine oil. Dont use it. It might work okay for awhile, but will shorten the lifespan of your engine. outboard engine has different lubricants, detergents, and lubricity than regular air-cooled oil. It will NOT lubricate or cool your engine as well as regular air cooled oil. Even though it says it can be used in water-cooled or air-cooled engines, it is still outboard engine oil. Trust that we are telling you the right information.
  14. Predator303
    Apr 26, 2012
    648
    I also got some rests of Valvoline TC-W3. Thats what I used for about 2 months. I want to get synthetic oil again but should or shouldn't I use it for the break in? BTW you are right there is a small outboard icon on it. Never saw that!!
    #34 Predator303, Sep 20, 2012
  15. bigbutterbean
    Jan 31, 2011
    2,417
    Any oil that is classified tcw3 is outboard engine oil. You want to buy oil that specifically says on the bottle that its for use in air cooled engines. Is there a walmart near you?
  16. Predator303
    Apr 26, 2012
    648
    It said for motorcycles air cooled too but I have to buy a new bottle anyways. Anything you can recommend from Walmart?
  17. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    i use honda hp2 currently its not bad on price and full synthetic but im thinking about trying the opti2 out 100:1 mix rate people are talking about but not at 100:1 mabe 50:1 irun the HP2 at 25-30:1 depending on how hot it gets if its hot out i mix heavy
  18. Predator303
    Apr 26, 2012
    648
    OK good to know. Here is crazy hot right now, even at night about 85-90 air temp. Thank you, I will look for that oil tomorrow.
  19. bigbutterbean
    Jan 31, 2011
    2,417
    lowrider, walmart sells conventional oil in 16 ounce bottles with a ratio cup built into the bottle for like $5-6. it will say supertech universal mix 2 cycle oil. not sure if it says air cooled on the bottle, but i know it is. its conventional, not synthetic. i have been using it for over a year. its maybe not the BEST oil to use, but it works, and it is made for air cooled engines. as far as i know, it wont hurt the engine if you mix it right. I run 32:1, which is 4 ounces of oil to a gallon of gas. buy a one gallon gas can, and you can mix the oil and gas in the can before adding it to your tank. for breakin, add a little more oil. there are a few others on this forum that use it as well, and I havent heard any comments about it shortening engine life.
  20. Predator303
    Apr 26, 2012
    648
    Oh that would be great a cup together with the oil. Thats what I need to look for tomorrow! Good tip!
