Break in secrets
Discussion in 'Motorized Bicycle General Discussion' started by wayne z, Dec 25, 2010.
  1. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    Hey, no problem. I am glad to help out. I buy those bottles specifically for the ratio cup. I have a two gallon tank. I ride right up to the pump, measure my oil, pour it in and pump my gas. no muss, no fuss. the way I like it.
  2. Predator303
    Predator303 New Member
    Apr 26, 2012
    648
    Thats how I do it. I have a little bottle in either my pants or my bag that have enough oil for 2-3 tanks and when the tank is almost empty I pour in the oil and premium gas and keep driving :) But now to break it in I want to be sure I have the right ratio.
  3. bigbutterbean
    Jan 31, 2011
    2,417
    just remember to look for supertech universal oil, and make sure it says 2 stroke on the bottle, not 4 stroke.
  4. Predator303
    Apr 26, 2012
    648
    haha I know it have to be 2-stroke :) Im pretty good with engines but since I dont have too much experience (except Yamaha Outboards 10 years ago) I rather ask than messing something up. Thank you
  5. bigbutterbean
    Jan 31, 2011
    2,417
    Oh yeah, I only say that because I almost bought a bottle of 4 stroke oil by mistake once. Basically saying dont make the same mistake I did, lol.
  6. Predator303
    Apr 26, 2012
    648
    I meant to say "not too much experience with 2-Strokes. Yeah I will look what I find tomorrow. Still working on the engine. Its mounted, now the carb and all cables.
  7. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    they also sell little bottles of pre measured 2 stroke at ace hardware and places like that and it says on the front what the mix is usualy its 40:1 for a gallon but if you put it in a half gallon tank it will be 20:1 i have one in my bag just in case its pocket sized
  8. Predator303
    Apr 26, 2012
    648
    Holy sh*t. I just measured the oil for a 25:1 ratio for the break in and I realized that all this time I probably drove the engine with something around 100:1 or 90:1 and I have never had any problems. Question: Do your engines smoke from the oil? Because mine never did unless I didnt drove it for a couple of days in the first minute.
  9. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    no mine dosent unless i over oil it i did this once during break in when i switched to the smaller tank and used the same amount of oil to 1/3 less gas
  10. Easy Rider
    Easy Rider Santa Cruz Scooter Works
    Jan 15, 2008
    2,148
    This is the way I've been doing my break ins for years. The most important part of breaking in a new motor is seating the rings. The best part is there's no need to put a non synthetic oil in your motor.
    I spray WD-40 in my new motor/cylinder then run it hard right out of the box.
    This will instantly seat the rings. However I only use high quality oil in my motors. (Bel Ray HR1).
    Bam!! Your motor is race ready in 2 minutes!
  11. Predator303
    Apr 26, 2012
    648
    I actually sprayed WD40 too in my new cylinder right now. First to clean the debris that was all over the piston and cylinder and when I finished and with head on top, I sprayed a little more in so it have some lubrication until the gas-oil mix runs through the first seconds it turns on.
    But, maybe you guys could help me here:
    http://motorbicycling.com/showthread.php?p=426952#post426952
  12. bigbutterbean
    Jan 31, 2011
    2,417
    WD40 is NOT A LUBRICANT! It is a SOLVENT! Once it dries out, it actually binds instead of lubricates.
  13. Predator303
    Apr 26, 2012
    648
    maybe if it dries out but i have never seen wd40 drying haha. it was just for the first couple turns of the engine. i rather have some wd40 on it than a dry piston in the cylinder. i usually use regular oil for that but this time i used wd40 because i already cleaned the cylinder with it anyways.
  14. bigbutterbean
    Jan 31, 2011
    2,417
    Friction and heat are what causes wd40 to dry and bind. it also reduces the lubricity of your oil and prevents oil film from building up on your cylinder (you WANT oil film on your cylinder).
  15. Predator303
    Apr 26, 2012
    648
    oh well it wasnt much
  16. bigbutterbean
    Jan 31, 2011
    2,417
    Doesnt take much. Ever sprayed wd40 in a padlock? works great at first, till the wd40 dries out, then it binds up and makes the lock stiff.
  17. Easy Rider
    Jan 15, 2008
    2,148
    I've done this to more than 10 high end motors and after I've taken the the cylinders off, there's always been an oil film on the cylinder walls. All the wd40 does is help seat the rings. It's an old racer's trick. I use grease for all my bearings and seals. A lot of how your motor last and performs is what kind of gas and oil you use.
  18. Bikeguy Joe
    Jan 8, 2008
    11,529
    The wd would be gone in the first few seconds of running, it's not going to hurt anything, lock anything up, or dry anything out.
  19. Predator303
    Apr 26, 2012
    648
    Exactly. It was just meant to be for the first couple turns before the engine fires up.
  20. bigbutterbean
    Jan 31, 2011
    2,417
    Not something I would ever try.
