Im a bit to blame there Tom, for turning it into the “what are you working on now” thread.
Not machining anymore, but when my old boss gets out of the hospital I may get some stuff made. Been drawing in 3D a lot the past couple years.
Yeah been thinking of putting a camper shell but if I want to sleep in the car often I’ll just get a suburban or some Japanese car with lots of space and good mileage.
I took out to restore, at least the drill press, of this 1952 August Rockwell Delta Saw Table Combo. Saw, Drill Press, 4" Jointer, and Sander.
With my nerve pain in left hand a bit of $@#, I am thinking Drill Press fully functional and maybe the Sander. Safety Third Camp at a Burning Man event I visited once, has a catchy name?
The newest saw tables have not just what I saw in the now defunct Tech Shop from about 10 years back that I was a member.
Back then it was only based on liquid detection to shut off the motor (i.e. blood), but now for some years, a capacitive change detection circuitis used. If a person the touches the blade of the table saw it changes the capacitance detected.
I was wondering how it could detect in a circuit with a metal blade that conducts while it is also turning. I mean, just touching then any part of the table would be at the same potential.
Newer is with two capacitive plates on adjacent sides of the metal saw blade A capacitive detection circuit has range values, it compares measure to these to know the difference between human body, wood, etc.
The act of touching the blade then does two things. It shuts off the power and throws a metal part activated by a solenoid to jam the blade to stop. By design it also has the blade recess downward and away from object detected as human body.
Something was said that making it a standard was not the best idea, I’m thinking they meant, instead put mind probe to tell in space where you’re going in relation to a quite dangerous moving sharp steel blade.
No, but I expect best not even touch the blade, maybe Lidar with something detecting just too close.
I will be using the hoist I made to lift my camper shell off my pickup truck, to lift the drill press to bolt it to the whole assembly. I had enough of this no plastic type weight on my back.
I have a furniture dolly I will put under the feet of the unit to move it around.
Then back to using the drill press to help with some holes precisely drilled for my catch can on my Briggs bike.
