LOL,  thanks Tom!  Addressing your question. I did just 'cause I can & to show how little pressure I was putting on the work piece with this tool & without kicking the work out of three jaw concentricity. The design of the radius tool always will mean exaggerated work stick out , but on work smaller than 1.5" diameter my rest would fine though I opted out  of using it for this test, which was an extreme setup on purpose. Once the radius work was completed the tail stock could have been employed, I had already faced and then center drilled prior to cutting the radius, and would always be used on a real fab project. I turned most of the time at about 550 rpm & with carbide on aluminum I was surprised at how well it worked. I had no chatter so I know i was dialed in on speed and feed for this material. HSS would have been a much better tool choice with a nice sharp tool grind. again a hard test for the setup.
This was a difficult test of the tool & machine and was indeed just an artsy show of the capabilities of both for small projects. Once I get round to building a roller bearing center rest for large and long stock, relative to the small dimensions of the lathe, I'll be able to use both a rest and the tail stock support. My Spindle has a max capacity of 7/8" so the 1" material had only jaw length only for support.
All considered I think this tool quite effective on brass and aluminum which are my materials of choice for decorative work.
Rick C.
