Best Chain Tensioner
Discussion in 'Motorized Bicycle General Discussion' started by b3anz129, Aug 27, 2011.
  1. b3anz129
    b3anz129 New Member
    Aug 15, 2011
    30
    Hey guys, my chain tensioner (just the wheel) broke off and I wasn't able to retrieve it. What's my best bet for a replacement? Should I get another wheel or make it a sprocket this time? Do any stores cary these things? I'd definitely like to get one as soon as possible :D.
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    A modified skate board wheel is what a lot of us use. Try for the one pioece style and you'll need a way to cut a groove in it for the chain. I've used a lathe and many have used a drill press with a grinding wheel.
    There are tension wheels available from several vendors but most will be just like the one that came with your kit. A good polyurethane wheel will run quieter and last longer than the plastic ones.
    You might try using the google search feature, use the keyword, 'tensioner' to see what others have done. There's many pages of reading on the subject. http://www.google.com/cse?cx=partne...ycling.com/f3/best-chain-tensioner-33176.html
    Good luck.
  3. The Busted Nut
    The Busted Nut New Member
    Aug 2, 2011
    96
  4. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    Go with the ten tooth it will be so much better
  5. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    I like the looks of those 10T sprockets but $25 is a crazy high for it price in my opinion, built all of mine from the skateboard wheels like 2door has with good bearings and grade 8 bolt, nut and washers for spacing, after 100's of miles on dusty dirt roads they still look and work like new.
    I groove them out so the chain rides half way down in the groove, I would be more than happy to make someone this same set up with grade 8 hardware included for half what that sprocket cost including shipping if they live in the lower 48, I know that sprocket is really nice, but $25 is a bit rich for my blood for something that actually does as little as it does.
    These are just my thoughts nothing more, nothing less..... (^)
    Peace, map
  6. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    You could even use an idler wheel from a junk bike's derailleur if ya wanted to.
  7. mapbike
    Mar 14, 2010
    5,380
    Yep, I remember seeing someone with one of those as an idler, seems it would actually work pretty good.
    Peace, map
  8. culvercityclassic
    culvercityclassic Well-Known Member
    Sep 27, 2009
    3,087
    57
    I think 25.00 for the sprocket type is a deal and ordered 3 to use on my special applications. This type allows the chain to operate smothly.
    I have thrown the chain three times and caused alot of damage.
    Btw: this is for a four stroke application; I never use a chain tensioner on my china girl rides.
  9. Mozenrath
    Mozenrath New Member
    Jan 13, 2011
    340
    Do the sprocket-type tensioners provide any better performance?
    I actually am still using the stock tensioner. I found that if the rear sprocket is perfectly tightened and if the tensioner is perfectly aligned with the engine sprocket, it won't move at all! So I've left it that way for months now. The only maintenence I've done was adding grease to the wheel so that the chain glides over it better.
    I do plan on adding a chain to the original tensioner like here:
    [​IMG]
    That way I can keep the tensioner and still give it something to prevent it from slipping into the spokes, just in case!
