Creative Engineering
What is so hard to understand about the s3x fixed gear 3-speed?
Go ahead and make it happen!...I wasn't arguing!!!
Jim
I mean the cog driving by the motor with the N.V.'s internal gearing working with the sprocket connected to the motor. That would mean no J Shaft and one chain to rule them all!![]()
Jim
Dpnt discount the tranny as jack shaft. Main trouble with SBP kit is all the added weight! Of course you lose mega power....
Never peddle, never fear a hill, and go faster than the direct-drivers while they peddle! heh heh
tranny as jackshaft for the win!
Your pic is exactly what I was talking about in my earlier post!!
Camlifter did that on his 'Biker Build Off' bike... He used a shifter hub as a jackshaft transmission! (genius)
I still believe this would be a better way to have gears. (Over a derailleur & multi sprockets.)
1) buy a fixed gear 3-speed.
2) attached sprocket to hub body.
3) install 22 tooth fixed gear cog.
4) mount.
5) ride.
SO everyone does realize that the s3x does not freewheel with a cog? And the cog does not un-thread when you drive it backwards? the s3x will drive on the left side and shift!
Maybe that's what some of you are over looking. 'fixed gear' bicycles do not free-wheel. The s3x is a fixed gear three speed.
i'm working on a project to run the nuvinci hub with left side drive, the free wheel will have to be welded solid and a 3 piece crank with free wheel fliped to the left. an idler mounted to the seat post, all using just one chain. the only draw back i see is the hub sprocket being welded on means that once it wears out you'll need to do another hub. but it should last many thousands of miles before that hapens. waiting on some hub oil and other parts but i'll start a thread on it when it's ready.
ballermj23,
You got it!
The Stainless Steel sprockets I made are for heavy duty bicycle chain...see post #82 in this thread. Like you said, a lot of people use the thinner chain without any problems.
The kit will include a new engine sprocket that has been machined with the correct tooth form.
The CAD graphic at the bottom of post #13 in this thread shows the total thickness of the cluster.
The cluster mounts directly to one of my sprocket adapters. The cluster will be positioned, (on the hub), so that the center sprocket is in-line with the engine.
I just need to make a deraileur and it will be ready to test.
Jim
Swap it to the other side...and see what happens!
Jim
I know it won't spin backward... & obviously you didn't read the part where I said "like Camlifter did".
Here's a pic of Camlifters 3-speed hub transmission... I know this can be made into a easy 'bolt on' system for HT engine kits!
