Venice Motor Bikes
Norm,
You are several posts behind!
Jim
I've seen you go days without commenting on posts directed to you.
Anyways... No fighting!
Norm,
Jim
that would work well for 4 stroke engines, there are more challenges on the 2 stroke.
Jim by when will be seen a test run or even a video.
to showoff the new shift kit or fail. haha
no really, i wanna know so i can look forward into getting it realize.
P.S people need to start getting on the bandwagon! Cause we are talking oFF!
Camlifter,
As always, I look forward to seeing your set-up.
It is fun messin' with these bikes...
The design possibilities are endless...
Jim
i'm positive i can make the nuvinci work backwards with a left side drive, and it should work great for the ht and hs kit motors, maybe even the 5 hp morini, but the s6s morini will probably be to much for any nuvinci. all the ideas in this thread are great, keep them coming, but what we really need as a gear box that can mount to the seat post, THUD has one in the works, he post mostly in the electric section. he has a 2 speed box, he had it on one of is hopped up electrics at the ohio race, he's still developing it, but what he is doing is the direction we need to go for a true trans that can handle more that 5 hp. maybe he will see this and chime in.
They do very slightly prolly helps shifting better.
Remember the old Bio pace sprockets? They faded out rather quickly. Turned out the folks using the normal sprockets were winning all the races.
**************Brainstorm!
It would be much easier to design a 2 speed internal gear hub (like a mirror of the conventional sturmey archer type), that took a standard BMX RH freewheel on the RH side.
In fact its possible that some existing planetary hubs can be reversed or modified, and threaded to take a standard freewheel . I saw a article called The Dancing Chain about a wierd bike that had 2 chains and used a modified IGH like that.
This would eliminate the VERY dangerous proposal of a left-handed rear mech and the large freewheel necessary. (The larger a freewheel cog), the "more" it wobbles!
So, if the Sturmey model can be driven backwards, and you have the motor chain turning it, how do you rig the pedal side? Are you using the rubber rag joint cog on the right side?
That is why I said if you can machine the hub to take a standard BMX freewheel, you could have it made, for purpose of this thread. I think it would be quite a high ratio though, on the motor side, in all 3 gears.
