Regarding gasbike, kings and bikeFerry...
They are exactly the same company and you made a mistake on the $200 price for a whole kit.
PS The so called "5G" Bikeberry kit with it's inferior gearbox should be on the do not buy list instead of a recommended list.
Nationwide Access LLC in Van Nuys, CA is the importer of the YD factories Grubee Skyhawk 2-stroke engines, the ONLY 2010+ EPA certified 2-stroke engines legally allowed in the USA.
The 49cc 4-stroke HS engine is EPA certified and pretty much a part for part clone of the workhorse 50cc Honda you see on commercial job sites running generators and compressors from sunup to sundown for years and years.
Unless you break the pull start rope they are great little reliable workhorses.
The 4G belt drive is nice and quiet when running but the clutch bell rattles like someone ringing a bell at idle which is annoying but liveable.
They are gutless for the most part to get them going but wind up nice, especially if you run them with gears, even a 3 speed like this.
And for hills not so great when direct drive like this...
... but do with some pedal help.
I am building another one of those now, the bike is here and 4G kit from gasbike is on it's way but there are other options like the 79cc HF Predator for $100 but once you add up all the other parts you'll need that come in the gasbike.net kit it will still be at $350.
I am about a week away from starting a completely custom 4-stroke build with this 6.5 HP (212cc) 4-stroke engine
http://www.harborfreight.com/65-hp-212cc-ohv-horizontal-shaft-gas-engine-69730.html
And this Auto-shifting Torque Converter transmission.
http://gokartsusa.com/GTC-TC2-Gokart-Torque-Converter-30-Series.aspx
There is a big difference between a centrifugal clutch and a torque converter.
Both are automatics meaning don't engage at idle and self engage when reved up, they just do it differently.
A cent clutch has a set of spring loaded pads on the engine output shaft that spain out and grab the inside of the bell housing that has a gear or belt sprocket and single speed and as mentioned before that bell tends to ring like one at idle.
A TC works differently and actually acts like a 3 speed transmission.
This is an excerpt from the link I posted above.
In short that front belt pulley gets larger as the RPM's go up thus changing your initial gear ratio which to me is cool as **** and I can't wait to try one ;-}
I think a kit with everything needed to center mount a 4-stoke including a decent light torque converter on a bicycle but with no engine that would take the HF 79cc or other HF sizes up to a 212cc you can buy at any Harbor Freight or a 50cc Honda or HS just as easy to buy locally would be a very saleable 4-stroke option for the do it yourselfer.
Kind of like a universal 4-stroke bike mount kit and you just buy the 4-stroke engine of your choice.
One final note on center mounted 4-strokes, kiss your bottom bracket pedal assembly, it's sprockets and shifter goodbye, unlike a 2-stroke your standard bike pedals won't fit around the much wider and heavier 4-stroke engine so you will need to replace the whole works with wider ones and that can really feel awkward unless you have ever rode a real motorcycle.
