212cc carb dowel pin removal?
Discussion in 'Motorized Bicycle General Discussion' started by jazz2561, May 22, 2015.
  1. jazz2561
    jazz2561 New Member
    Sep 20, 2012
    269
    Does anyone know how to remove the carb dowel pins on a 212cc predator? I need to make a custom manifold and I need to either shorten, or completely remove the carb dowel pins. Is there a way to thread holes once dowel pins are removed?
  2. scotto-
    Jun 3, 2010
    6,530
    6
    You must have the Hemi head 212cc (newer model) engine.....none of my 212's have dowels on the carb manifold, sorry I can't help you on this one. :(
    You should be able to tap the holes with the proper sized metric tap.
  3. jazz2561
    jazz2561 New Member
    Sep 20, 2012
    269
    Not dowel pins, studs. Im sorry. How do you remove the studs?
  4. MotorBicycleRacing
    Jul 28, 2010
    5,686
    27
    Vice grips if you don't care about ruining the studs.
    Double nuts as in lock two nuts together to not ruin the studs.
  5. jazz2561
    jazz2561 New Member
    Sep 20, 2012
    269
    Do I turn them clockwise or counterclockwise to remove the studs?
  6. dtv5403
    dtv5403 New Member
    May 4, 2015
    322
    Lefty loosey righty tighty
