your work is definitely inspiring, keep the posts up! so far i have the HF engine a welder, angle grinder, band saw, clamps and gloves purchased for the build i will do. you used the hf tube bender with th wheel right? it looks like it got decent reviews for bending 1" tube, what are your thoughts?
no doubts i will be hitting you up for info when i get started. definitely want to get a comet cvt and do a similar spring and sprocket setup. i feel you on the job wife dog other projects thing... its why it is taking me a year to restore my honda, almost done. better get on it though, Texas summer is coming and those can be brutal!!![/QUOTEI
I got the bender without the wheel. It was good for everything except the drop loop which was too much of a bend and required a radius bender, so I used a guys down the street. Before you make your frame make the wheels with tires and get the comet connected to the engine. it will be a lot easier for you. I was lucky because I made a large enough frame to fit everything. If I was an inch too small I would have had to cut and redo much of it. Here is the most important measurement. My bike is 77 inches long (6'5") from end of tire to end of tire. I wish I added 2 more inches to this, but I'm ok. Length is a big deal to making it look right.
