I got my bike all built and adjusted and running great, and then about a mile into my trip, my chain tensioner decided that it would throw itself into my spokes, ripping about five or six of them completely out of the wheel, ruining the chain, motor mounts, wheel assembly, and tensioner. even the tire itself is wore down from having to push it home locked up.
On top of it all, I have a rediculous burn on the side of my knee from the engine.
That really sucks, I hope you don't get discouraged from continuing to build and ride motorized bikes. I don't use the chain tensioners, instead I put spacers in between the rear engine mount block and the engine so the engine is moved forward and the chain is tighter. Is the rim damaged? Spokes are cheap, just need to install them. The spokes may have pulled on the rim and damaged the holes. If that's the case you need a new rim. I hope it wasn't a really expensive bike.
