Catching anyone up since my last post. After mounting the 212cc, i found that the COMET torque converter would not fit. The back of the plate butts up against the seat post. Theres no adjusting, flipping the plate, etc that will make it work. So after todays research, here are the options.
1. I was told that the stock torque converter that comes with the Death Row kit is a tad bit longer, without the groves that would offset the converter, would fit perfect. He said hes 80 percent sure it would fit. - cost 83 dollars on gasbike.com https://www.gasbike.net/products/transmission-for-212cc-death-row
2. I found this torque converter on go kart USA thats seems pretty legit. With a flat plate the groves (that were originally on the COMET) wouldnt offset the placement. My only concern is that it may to be to short and again, the back panel would hit the seat post. gokartusa.com
https://gokartsusa.com/Comet-TAV2-GTC-Torque-Converter-Predator.aspx
3. I found this centrifugal clutch on amazon for a 79 cc. Being that the plat is short, flat, it would clear the seat post no problem. Does anyone know if this 79cc would also work with the 212cc ? https://www.amazon.com/TRANSMISSION...coding=UTF8&psc=1&refRID=60XPMJZ08BYAHH1DQ1ET
4. The more savage of all ideas, but a buddy said i could try cutting the fins off the COMET torque converter and flip the plate so that it doesnt hit the seat post. The only thing with that is that it would be highly nonadjustable, and if it doesnt work i couldnt return it.
All great options, what do think? Does any one have any experience with a similar issue ?
