Looking for a good air filter
dishpointing
8
PUERTO RICO
Hi guys any recomendation on air filter for the "80cc" engine, seen a few mostly from pocket bikes that include a velocity stack.
All opinions welcome, this a enjoyable hobby.
brnot
saolom
48
Australia
Heres my DIY filter for less then $10aus . I use a oil can/ breather filter from Autobarn and modified the inside to make it fit around the circle groove inside. Using two tiny wood screws to hold them in. Blk silicone around the edges for air tight. Fits great and works Really good!.
Prasinos
261
California
you can pretty much mount any pleated air filter on your bike. Go to a tractor supply or other hardware shop and pick one up that looks close to the size of the old mount, then tape it on or make a mount so you can use the screws.
85pulsarnx
10
racine,wisconsin
I got a good one, spectre performance auto parts sells a mini cone filter oil breather
its polished,available in many colors,and installs with a hose clamp
plus it looks just like a cold air intake from a car =D
Cabinfever1977
2,288
Upstate,NY
o by the way,your throttle cable on top of the carb is loose and not sealed.
you might want to seal and tape it tight.thats called a airleak.
