The Lifan flathead engine was replaced with the OHV engine, though some old Lifan info on the internet still lists the information. Motomags advice on finding a used one is a good place to start your search.I can not seem to track down the correct engine.
The homedepot site has.
Internet #203281925
Model # LF152F-3Q
This may or may not be the correct engine.
There you go...options.
Experienced bicycle riders avoid severe cross chaining just using leg power so it makes great sense to avoid cross chaining under motor power. Straight chain lines are your friends when biking. 3 or 4 cogs are more chain efficient, two for accelerating and one for running. The cassette stack re-configured with only the preferred ratios and those spaced and shifter adjusted accordingly. Fine tuning with motor sprockets for ultimate performance. Though I've mixed thoughts on which rear cog the "perfectly" straight chain line should be set to, I lean towards running second gear dead straight and thus having low and high gear slightly askance, if three gears are used, my preference...with 4 or more cogs choose your poison.8 speeds is a lot of gears. Do you skip gears? Oh like the bike ! I actually went to 3 speed because on was having to skip a gear every shift. But every one rides a bit different!
As a bicycle mechanic, I understand the effects of cross chaining. This is why I center the drive sprocket on the center of the cassette, so it acts more like a 1x mtb system and minimizes cross chaining. I'm now also using an 8 speed E-mtb chain, which can handle that 80Nm of torque the 48v 1000w motors are putting out, which is a level my little 79cc engine could never hope to achieve (it's about 15ft/lbs). And if that isn't enough, I will soon be buying an 8" stainless steel disc to go between my chainrings so my chains do not end up grabbing, and chamfering and polishing the edges so the chains just slip right by.Experienced bicycle riders avoid severe cross chaining just using leg power so it makes great sense to avoid cross chaining under motor power. Straight chain lines are your friends when biking. 3 or 4 cogs are more chain efficient, two for accelerating and one for running. The cassette stack re-configured with only the preferred ratios and those spaced and shifter adjusted accordingly. Fine tuning with motor sprockets for ultimate performance. Though I've mixed thoughts on which rear cog the "perfectly" straight chain line should be set to, I lean towards running second gear dead straight and thus having low and high gear slightly askance, if three gears are used, my preference...with 4 or more cogs choose your poison.
Having a wide cassette with 6 to 8 cogs works well with 3 cog selections up front on a bicycle, but only if you avoid using ratios that cause wild cross chaining: like running large cogs to large rings or small to small. The angles formed by the chains in these relationships is extreme and put the drive train in stress and promotes increased wear and or breakage to occur.
Moto you made a wise choice in going to three, for riding performance alone. Your also correct when you say we ride differently and I would add to that most don't understand what riding correctly entails.
Rick C.
Yep, I will not be using any chain other than the JT 420 power transfer I've got on my clutch once I get that 250 twin built. There isn't much that can take those 18 horses in the bicycle world. Stuff gets too heavy.Thanks for the reply. Road & mountain bike guys get it. Done right it will and does work with small motors, but then there's the rest. I hope the disc is a success!
Rick C.
Stopping power is lacking with the mechanical BB7s. 20mph-0 in 50ft with 160mm rotors on 5lb wheels. Now, with the new hybrid hydros, I can stop in 35ft. 180mm rotors with lighter wheels will bring that down to less than 20ft. My tires are 26x2.125. I'm slappin on 2.3s now, without the square edge.Will have to learn allot to make this build work.
Indian22 makes some great points. Pull starting my bike will get old fast. Do not want the lawn mower look or the wear and tear on my shoulder. The 3d clutch looks very nice and would fit well with that GTC jackshaft setup MotoMagz is using. The blue bike with disc brakes and some paint is basically what I want. Still debating 26x2.5 vs 24x3" wheels.
@ xXNightRiderXx How well were you able to stop with macanical disc brakes? What size disc and tires are you using? How fast is a 79cc predator? What do you think about that exhaust setup? Did you do any other performance upgrades? Any large hills in your area?
If you're using mag wheels, then yes, a 180mm rotor will be needed with hydraulic brakes at a minimum to pass inspection (they will ask you to do a brake test).Starting to think 203mm disc may be needed. Looking to max between 40 to 45mph and cruse around 28mph. I think AGK stopped selling the billet flywheel. The fastest 79cc bikes seem to all have the AGK carb or NT carb. Looking at reusing a 2 stroke exhaust pipe with all the insides removed and small adapter to get correct angle.
