Really just looking to see if there is any cdi that might help my bike at low RPMS. I feel like the spark is too advanced when starting because it wants to kick really hard when below idle speeds. Saw some graphs about jag intiion being retarded more than stock below 3krpms and i liked the sound of that.
Also doesn't like to idle very smoothly when it is started, so maybe a stronger spark would be nice?
Is the consensus that no aftermarket CDI will help much?
My bike as a DIO reed kit, windowed piston, SBP expansion chamber, dellorto clone carb.
I kind of assume most of my problems are still with the carb, but i wanted to try a different ignition to cross that off the list.
Personal preference: The more knobs I can turn with a part the better...
In general... the stock ignition box has a really good timing curve & works very well with all 'high performance' parts.
The GasBike CDI's also work very well if you absolutely have to have something other than a stock box.
All those other CDI makers are gone now.
All these 2-stroke engine kits run rough at low RPMs... They're geared to run smooth at higher RPMs. (don't ride it too slow)!
As far as the aftermarket parts that you have on your bike; The DIO reed is one of the worst out there... (I've always preferred the Arrow Racing style reeds)
Those Delorto clone carbs are terrible to tune!!!! (Seriously... I'd rather use a stock NT carb than the Delorto).
Those SBP pipes don't do anything... (You can get the same increased performance by simply hacksawing off the end of your stock muffler)
The best expansion chamber pipe (other than modifying a real 80cc dirt bike pipe) would be a genuine MZ Miami pipe... But it's difficult to find a genuine one. The MZM clones aren't very good either.
