Thanks Steve Like a lot of things I didn't know about myself till middle age when quite by accident I found I could draw & then expanded it to paint and sculpture. Same with writing my first book which dealt with the art of crafting fine double guns...side by sides & the history of such... primarily English, Scots and American makers. Then some 25 years later I wrote my first novel.
Thanks for your help and all others who took time to do a little research...it's fun, no?
The special ops folder was a fluke of contracting govt. work & resulted from a quite different contract & contacts with procurement in that process. Time from design to acceptance of the prototypes was lengthy & really not terribly profitable, but actual time spent crafting wasn't too extended, perhaps a month or so to build 4 weapons (one was for me)...the blades of course were the most time consuming, made of a stainless ATS 34 as I recall, the properties of this special material was unique in that it took an extremely sharp edge quickly and holds the edge well in hard use which is indeed impressive; if you've owned many stainless blades & hated trying to sharpen them, then find they also dull quickly. Also I purchased the blade blanks in Japan & the steel grain was magnetically aligned to follow the special contour of the Tanto style blade. This allows the blade to be sharpened along the full length of the steel tip to bolster even though there is a radical change of angle at what would normally qualify as the belly of the blade leading to the tip. The delivered prototypes were also back sharpened, so as to cut coming and going, as they say, without turning the wrist. This is illegal to carry in the U.S. - my blade isn't back sharpened, but it's still not legal to carry in most of our states because the blade is too long, it's an automatic (switchblade) though it's design, which can be completely disassembled by the removal of 2 screws and the hinge pin for field cleaning, allows the disengagement of the auto feature. At that point the knife continues to function as a gravity blade (also illegal) this dual feature allows the blade to be just as functional if the blade actuator fails & should the blade be stuck full of mud the back of the blade has a one finger opener as well. All fail safe features that are kinda important in a fighting knife. It's also a heavy weapon and acts as a bludgeon, in it's closed position, on both ends. So it's not legal to carry period. Simple, durable and deadly just what the guys in charge ordered. The blade also has two safeties to assure the blade can't possibly close during use, which would quite likely sever the operators fingers should that occur and since blood is slicker than ice on ice the bolster and scales of the knife are designed to keep the operators hand in place and not slip forward onto the cutting edge (which quite commonly occurs in knife fights and in skinning wild game as well) just some of my recollections of a weapon built and sold & I hope never employed for it's intended use, but if used I pray American lives were secured. Rick C.
