The bike is clean . I like it a bunch.
It'l be interesting to see how it rides with the riser in the forks.
I like the idea. It should actually slow the steering down a bit...
A good thing on gravel roads.
I'm with you on the BGF thing. I haven't sed anything to date ( not my place ) but wow....
A confusing and confused character for sure....
I will continue to fallow your build , as I always do .
You sir are a wealth of knowledge .
Dave did you buy your powder system from Harbor Freight?
If so, I have had the same system sitting in the shop. Not even sure where or when I got it....
Haven't used it yet .
The toaster oven comment turned on a light in my dim brain....
Thanks . I now will need to buy a new oven for the wet bar as I have new plans for the existing one......... Gregg...
Thanks for the kind words Gregg, Im just a simple tinkerer, many people here like yourself with way more knowledge than I, but I try to share what I know and hope it will be helful.
Yeah the extra rake will slow steering a little I think also, my Harley has the stretched front forks and whne I get on my old XJ650 Yamaha after riding the Harley for a while I have to be careful, Yamaha has quick reacting steering while my Harley has to be forced a bit more to turn, at slow speeds to much rake makes a bike feel a bit floppy and I dont want that on a motorized bike since slower speeds are common for making turns, but as long as it doesnt have that kinda floppy feel at low speeds Ill be fine with it..
I have some 1" shaft collars that are about 1\3 the length of the spacer I have in it now and I may just chuck one of them up in the lathe and bore it out to 27mm partially and use it on the bottom and then cut the current spacer down to an ideal length and use itto take up the space on top, this way the forks would only be about 3\4" longer than normal.
I know what you mean about Dave bringing up the toaster oven idea, bells and whiztles went off in my small amount of grey matter also...... Ill be looking at good will or similar places for a large toaster oven now so when I can get me a powder coat rig Ill already have the oven for doing the baking.
Shan
