silverbear
The Boy Who Never Grew Up
Here is lowriders post #39
"I've got 2 MB's that are V-Belt drive. My method is to mount another same-sized rim to the spoked rim. I clean both surfaces up with a file & some rubbing alcohol, then JB Weld together, then drill small holes through both (not thru the tube channel & bolt together w/ a few thin bolts with nylock nuts. They haven't needed truing with thousands of miles on them. The extra rim (pulley) strengthens the spoked wheel. I run powerful, fast engines (Lifan 2.5 hp 98cc & Stage 2 Pocket bike engines) & the setup seems to handle the loads just fine so far...
-Lowracer-"
This strikes me as absolutely brilliant. Thanks for bringing this low tech, low expense idea to our attention, Anne! When you do it, take some pictures for show & tell.
SB
-Lowracer-"
SB
