Rear belt drive?
silverbear
The Boy Who Never Grew Up
Jul 9, 2009
8,325
670
northeastern Minnesota
Here is lowriders post #39
"I've got 2 MB's that are V-Belt drive. My method is to mount another same-sized rim to the spoked rim. I clean both surfaces up with a file & some rubbing alcohol, then JB Weld together, then drill small holes through both (not thru the tube channel & bolt together w/ a few thin bolts with nylock nuts. They haven't needed truing with thousands of miles on them. The extra rim (pulley) strengthens the spoked wheel. I run powerful, fast engines (Lifan 2.5 hp 98cc & Stage 2 Pocket bike engines) & the setup seems to handle the loads just fine so far...
-Lowracer-"
This strikes me as absolutely brilliant. Thanks for bringing this low tech, low expense idea to our attention, Anne! When you do it, take some pictures for show & tell.
SB
MEASURE TWICE
2,775
1,274
CA
Section belts I wrote a lot about in my Art Fish MB maybe Side Car... thread.
Of the section type belts, the green Accu-Link belt at HF is not as tough as the red Power Twist Plus, which I got a Grainger.
No way am I saying don't use section belts, but they just could not take the tightness I wanted so the belt would not slip. For looks maybe they serve a purpose and get buy with low torque like alternator, but otherwise not a good choice for my dirt bike.
I use the AX type cogged v-belt:
http://www.gates.com/products/industrial/industrial-belts/heavy-duty-v-belts/tri-power-belts
http://www.gates.com/products/autom...d-accessory-belt-drive-system/tri-power-belts
Around small diameter pulleys they are not as good as a regular v-belt.
Even better though is use the cogged v-belt that is not a toothed belt to fit the synchronous type pulleys, but just bend around a smaller pulley better. Cogged belts do not wear as bad on small diameter pulleys.
You would have to make a way of tightening the belt and belt increment usually in 1 inch increments can be an issue, but I wanted 20:1 ratio 3hp 4stroke Briggs to climb hills a much as I could. A chain is really necessary, especially if the bet gets really wet. I may make a splash guard to help.
After riding a bit and getting grime on the pulley and belt, I clean the belt with only a towel a water. The pulley made of metal I clean with acetone to remove all trace of grime and then things grab.
See my last trip to the woods:
http://motorbicycling.com/showthread.php?p=595150#post595150
MT
silverbear
Jul 9, 2009
8,325
670
I see that the cogged V belts are reasonably priced. I can see where they would hug a small diameter pulley better than a regular belt. I was figuring on an idler pulley to keep tension no matter what kind of belt I end up using. Still curious about the linked belts and may still buy one to experiment with. I can always use it on the drill press, grinder, compressor or table saw. MT, thanks for your take on things and relating your experience. I don't foresee off road riding or in rainy conditions for myself, but you can always get caught in a rain.
Your bike does well on the trail ride and sounds good. Is that your new go pro clone camera? Nice footage!
SB
MEASURE TWICE
2,775
1,274
CA
The SJCAM SJ4000 Original does work well. I'm and wondering now about some low volume buzzing sound sometimes now, but not earlier when I got it. This only when I turn it on when it is already plugged in a charging the battery.
Something about the version firmware I have heard, but am leaving it be. I think it is normal for all the SJcams. I think the person who wrote about this as being a problem thinking it was precursor to the cam failing, locking up or whatever, is just circumstantial. I feel it best not to mess with it.
About either section belt, they just don't have enough contact surface area to really pull with 3hp 20:1 ratio up a hill.
When I got disgusted having even the regular belt on smaller than 3 inch diameter pulley under high tension and torque forces, I switched to gears and short chain.
It turns out that although I have twin jackshafts, I did no longer need them both to get 20:1 ratio when I replaced weaker aluminum rear wheel washing machine pulley with a stronger but larger steel sheave that had about 20 percent larger diameter.
But then I found out after replacing my muffler tail pipe from weaker copper or stainless flex water pipe that had modified copper gaskets, for high temp, now changed over to thick solid cast iron/steel, I did need the second jackshaft to make clearance so it would fit. No waste there. Also clearing the stays without modifying frame, the extra jackshaft gave flexibility to design.
If I ever want to climb walls at 5 mph or go parade speed (legal for DMV Dept of Mutant Vehicle Burning Man Event) dressed up motor bike as a California Sheepshead Fish style, I can do that with gear change between top to bottom jack shafts and make up another slightly longer chain. One jackshaft is adjustable to set tension on chain perfect.
I just saw that a Boeing 747 with wings removed and to be heavily modified as mutant vehicle for 2015 Burning Man Event may come to life. This means I can swim my fish looking for krill swept up under its trucks as it rolls across the playa's 30 thousand year old dry lake bed at 7000ft elevation.
MT
silverbear
Jul 9, 2009
8,325
670
MT,
I know your art fish bike is set up for applications most riders will not need, so it is hard for me to translate your experience to what most of us would need a belt drive to do. For myself there is no need for being able to climb billy goat hills or walk along slowly enough for parade ground situations. It sounds like your needs are best met with chain final drive. My own needs are more typical in being able to start off from a dead stop without excessive slipping, climb moderate hills and run along smoothly at a maximum speed of 35mph and most often 20-30 mph... the same kinds of situations an old Whizzer motor bike was so good for. For most of us, if we can come close to a Whizzer experience with our bikes we'd be happy campers.
For myself I want to try a belt final drive. As for which belt will work, a nice thing is that there are three types to try. Your comment regarding a small diameter pulley doing best with the cog belt is helpful and might suggest a larger drive pulley when initially setting things up if the link or V belt is desired. We can try one type and if it is found lacking, then try one of the other options.
SB
silverbear
Jul 9, 2009
8,325
670
http://www.ebay.com/itm/Washing-Mac...803?pt=LH_DefaultDomain_0&hash=item4857d6464b
MT had mentioned at one time using an aluminum washing machine pulley (which did not work out for his needs, I guess) and I thought I would check that out, my thinking being that discarded washing machines have pulleys for free. I went to ebay for a look and found that most standard washing machine pulleys would not be applicable for attaching to a sprocket. However, one type from Hong Kong looks like just the ticket. You can see in the link that this one with a diameter of 95mm (3.7") is only $9.59 shipped. It would be easy to drill and bolt it to a rag joint sprocket or in my case to a manic mechanic sprocket with worn teeth. No, these are not high grade pulleys and are described as being "metal" which probably means pot metal or a low grade of aluminum. But how good does one need to be since it is to be bolted to a sprocket?
There are a variety of sizes ranging from 3.1" to 5" diameter, all for 1/2" V belt. I'll need to measure the driven sprocket on my bike right now to see what the diameter is and then give a stare at the driving sprocket on the back side of my transmission to see what diameter that is. Might be that I can bolt one of these pulleys on to it as well so long as the drive ratio works out.
At the very least I can order a pulley for the driven sprocket (the one on the rear wheel), purchase a link belt from Harbor Freight and experiment with my Panther this spring. I won't wait to change the engine, but will try the belt drive with the current engine as a kind of "proof of concept" experiment to see if the idea works. I should be able to keep costs down to the $50.00 range ($25.00 for the link belt which I want anyway, another $10.00 or so for the driven pulley and another $10.00 or so for the drive pulley = $45.00). That won't break the bank and will tell me more than I know right now about a do it yourself belt final drive conversion from chain & sprocket drive. I think I have something I can use for an idler pulley if I need one. If I'm barking up the wrong tree here, please give a woof guiding me to the right tree.
SB
silverbear
Jul 9, 2009
8,325
670
Could be pressed steel. Whatever the metal it is probably adequate for our purposes. I did some measuring just now on my sprockets to match pulleys to and need a large one for the driven sprocket which is 10" diameter. I had to go that big to compensate for the sidecar. I'll see what I can find on ebay in something used that big. Shaft size doesn't matter for me if it is getting bolted onto a sprocket.
SB
MEASURE TWICE
2,775
1,274
CA
I sort of think that color which is not silver/white, it might be pressed steel.
You did some good searching. Free shipping, but I expect if you order distance ship for free, think wait time to get it. You though have a plan going though, I sort of kept things in my mind and wrote some down. Some how it works alright.
You already once built a motor bike with side car I think, so you have an edge!
Yea, I will get to finish building art cover, but other things has it on hold.
MT
silverbear
Jul 9, 2009
8,325
670
I got a note from Curtis Fox this morning which raises some legitimate doubts about what I'm attempting to do. I appreciate his thoughts on the subject which make some sense to me. When you look at old motorcycles which were belt drive they never have small diameter driven pulleys. With all of the variations that were tried in those early days you would think you'd see a small sheave. But I've never seen one and maybe that's for a reason. Here are Curt's thoughts on the subject...
"Good morning
Last night i was reading the post that was about pulleys,don't know how i missed it. But i don't think it will work,think of the 10" pulley as a lever. If you spin the back wheel with your hand it turns easy,but if you reach down and turn it with the sprocket it turns a lot harder,and takes a lot more force. Chain has teeth were a pulley has just the rubber against the metal. With that small of pulley it might just slip all the time as not enough leverage. Yo have the bike right there try turning the wheel with the sprocket then turn it with the tire.
I was going to post this on that forum you can if you want. About the smallest pulley you would want to do on a 26" wheel is a Wizzer. a 20" rim would be close to that size as the rim is smaller then 20" more like 16" If you studdy the old bikes like harly you will see the are mounted with Z shaped metal tabs that just bolt or riviet to the rims. Like Harry and the beach cruser or Mr.B and the excaliber. That also creats another problum with the bigger wheel pulley you have to drive pulley up closer to the seat to get the belt through without cutting the lower chain stays. Look at all the truble Measure twice had with his setup before he bought the Wizzer pulley. If it were me i would use a 24" rim for a pulley on the rear,and run a suppertean belt like Mr.B did. Or just a V belt. Sure hope i didn't blow the bubble but i just don't think it will work
Curt."
So what do you think?
SB
silverbear
Jul 9, 2009
8,325
670
And Curt has given me yet another thing to consider.
"Just some thing to think about. 2" pulley divided into a 10" pulley is= 5 to one ratio A 2" sprocket is about 14 teeth and a 10" sprocket is about 50 teeth 14 into 50=3.5 to 1 or there about. so you can see that chain and pulley are different"
And I thank Curtis again for something else I didn't know. So If I had a sheave that was say 20-24" about what size drive pulley would I want? Something like a 3 to 1 reduction is what comes to mind, but that seems like a pretty big drive pulley, what, about seven inches? (Obviously I'm not real good with this stuff coming up with the answers. But I can ask questions like nobody's business.) And if the driven pulley was 10" (assuming that it would work) then the drive pulley would need to be around 3"?
Just measured the Whizzer sheave and it is roughly 14 1/2" in diameter. Not that much bigger than 10", eh? If I try it then it will definitely be with a cog belt to get the most bite I can. Whether or not the belt has excessive slip is what defines success or failure. The smaller the sheave the greater the chance of slipping, yes? It would sure help if I was smart, but I'm not letting a little thing like brains stand in me way. Onward!!! On, you huskies... arf, arf!
SB
curtisfox
6,082
4,059
minesota
Its more the cercumferance then then the diamitor witch is 3.14 times more surface( more bight ) Yep 24 divited 8= 3 to 1. Its what up front that gives you a steep ratio,don't know what the Q-matic has for ratio. Most of the older bike run about 3" to rear Wizzer pully. Thats close to what my old Monark twin had for setup,and is the same as Wizzer. ................Curt
silverbear
Jul 9, 2009
8,325
670
Thanks, Curt.
I learned today from Tinsmith that EZm has already done the conversion of the Q-matic to belt final drive. I don't have many details yet, but it looks like they are using a standard Whizzer sheave with a 3" drive pulley at the clutch. I started another thread...
http://motorbicycling.com/showthread.php?p=595537#post595537
...in the hope that one of our forum members knows more about it or is even using it. I saw a picture on another bike forum of one of Helmut's frames with what looks like a Whizzer sheave and a belt coming from a Q-matic. Looks good, too. This was from 2008, so there must be some people out there using it.
I went to the EZM website hoping to learn more and didn't find much. No details about cost or anything, but I sent an email asking for particulars and will pass along what I learn.
Curt, the more I think about what you said regarding the size of the driven pulley makes sense. Bolting a pulley directly to a sprocket may be a dead end. I don't want it to be and hope someone tries it, but I think with what I want to do I'd be best off using a 3" drive pulley (don't think there's room at the transmission for anything bigger anyway) and a standard Whizzer sheave. If I can figure a way to use a bigger drive pulley then I'd like to try lowrider's approach using a 26" rim bolted to the wheel rim. Lots less money involved. I don't remember what a Whizzer sheave costs, but they aren't free.
Thanks for all your help, bud.
SB
curtisfox
6,082
4,059
minesota
14.5 divided by 3 =4.8 to 1. Last i looked they were $39 but you can look on the bay and find them cheper i think.................Curt
silverbear
Jul 9, 2009
8,325
670
The one on ebay comes to about $50.00 with shipping. I think I will explore alternatives. I have a lot of bicycle rims and was looking at Briggs & Stratton conduit clips for holding a rim to the spokes.
http://www.ebay.com/itm/Conduit-Cli...7&pid=100005&rk=2&rkt=6&sd=400842180129&rt=nc
I ended up having to use these for my whizzer rim on the kindalikeawhizzer build since the clips which came with the sheave did not fit my 11 gauge spokes laced in a four cross pattern. msrfan suggested using these as an alternative and they work great. Expensive little buggers, though. I believe I still have some. Another option is that I may be able to use the unused whizzer clips with a bike rim for a freebie sheave. I would think that a rim from a 16" to 20" wheel would approximate the size of a Whizzer sheave. We'll see. If I can save $50.00 and also have the satisfaction of making do with what I have, that would be very cool.
SB
silverbear
Jul 9, 2009
8,325
670
Yep a 20" wheel is about 16" without the tire............Curt
Perfect...
By the way, those conduit clips need to have the little tab deals ground off. Think I'll take a look through my wheels today for a sheave, just to know whether or not I have something suitable. If not, I'll keep a look out when making dump runs. It is never too soon to start setting aside parts for a future build.
I can't remember, Curt. Your bike project is to use a Briggs engine if I remember right. Are you planning for belt drive?
SB
curtisfox
6,082
4,059
minesota
You will have to measure for sure, but bike wheels are measured with the tire on and are smaller without the tire. Went through Harry's villers beach cruiser build trying to find pictures but they seem to be gone. That is what he used with Z shaped metal tabs bolted to both rims. But then you might run into clearance with the stays, seems to never a end to the work of doing belt drive. Prolly why you don't see to many. I know that Mr.B did on with tabs on his Excaliber 09,that way you are turning the rim and not the spokes.
My briggs build will be belt primary and chain to the rear, as i want to do as i did as a kid. But the one coming after { Fox Burro }will be belt drive. Had that Monark twin when i was a kid sold me on it, quiet and smoth just the engine hum,with the long fishtail exaust.
Trey
$50 Cruiser
Jan 17, 2013
1,432
5
Where cattle outnumber people 3 to 1.
SB- I've been reading along wondering why you're deciding on attachment methods... Because it's not in this thread... and THAT is: someone (wheelbender?) mentioned bolting an unused rim of the same size onto the rim of the drive wheel, and another member (not you after all) said they thought that was a fantastic idea, and would try it. I'm missing lot's of details, but it was someone who I thought knows their stuff. I'll try to find and link it.
Trey
