Very nice bike, Scott. I think I need to Chang motors to a pred.
Tang
The trail life for me.
Scotto
I'm currently, or going to start, a Dyno build. What did you use for a rear hub? I measured the rear dropouts and its 110mm. Did you spread your dropouts to 135mm to get a disc break hub in there?
I'm only asking because I'm unable to find a 110mm disc hub besides the Dam good engineering one.
Thanks
What size is that rotor you ended up with on the jack shaft?
I can only seem to for 160mm and if I do the same as you did, I like the cleaner look of the small one.
Yeah, I like the subtle touch it adds. Does it give you any issues stopping with it that small?
Niiice. It works that way even with the centrifugal clutch? Been a while since I've ridden anything with one...
Is that an RLV muffler on the end of it? Does it rob much power? I been riding with an open header for a little while and its getting old. I rode to the gas station today with no helmet and the noise was appalling.
Also what size carburetor is that?
AND.!! how you like that drum brake in the front. How's it compare to a 200mm disc?
