I have the specs on the 20kW BLDC motor. I have the specs on the 40-50C batteries. I have the specs on the 500A Field Oriented Sine Wave Vector Controller. I also have a calculator and all the calculations are in line with each other and speak for themselves. Speculations and approximations are pretty much meaningless at this point.Okay, NOW I'm done with you, you're an completely out of touch with reality or the laws of physics regarding what you intend to do. You'd rather spout a bunch of BS words on here than put in the homework required to make a reliable bike that you will enjoy riding that will actually meet the performance claims that your repeatedly spout off on here like anybody really gives a crap, as if big talk ever meant anything when the rubber actually hits the road.
YOU NEED TO UNDERSTAND HOW A BASIC ANALOG ELECTRICAL CIRCUIT WORKS!
You're hopeless. I hope you are able to wake up in time before you set your bike on fire, shock yourself badly, burn your batteries, controller, or motor to the ground, or have your unbraced rear frame structure crack off at high speed if you actually luck out and get something together that will move forward.
I tried to help you, but you won't listen. Ignorance will get you nowhere when dabbling in engineering, and you will pay for doing things the hard way by learning from mistakes when dealing with high power electrical or mechanical assemblies on a frame which is questionably constructed.
Good luck dude, realize I have the best of intentions, and you have had an arrogant and ignorant approach toward my advice trying to point you in the right direction.
I wash my hands clean of you, you're beyond saving. Wear lots of protective clothing, lol.
"Do or do not, there is no try."
