The following is most likely TMI, but hopefully it will clarify things a little.Hi
can you show link for hf142, I'd get it for my 2nd bike
sorry didn't mean to ignore you, 8000 rpm would be sweet ride , at that speed with my luck i will probably be going weeeee weeee all the way to hospitalThe following is most likely TMI, but hopefully it will clarify things a little.
There is a HuaSheng 142F, also known as a HS142.
http://www.bicycle-engines.com/49cc-Gas-Powered-4-Stroke-Engine-Five-Eighths-Inch-Shaft.html
There is no HF142.
The HS142 is 49cc, has 2.5 horsepower, peaks at 6800 RPM and redlines at 8000 RPM.
Then there is the HF79.
http://www.harborfreight.com/engine...cc-ohv-horizontal-shaft-gas-engine-69733.html
The HF79 is 79cc, has 3 horsepower, peaks at 2500 RPM and redlines at 3600 RPM.
Both can get you moving fast down the road, they just need different gearing to do it.
The HF79 has more torque so in most gearing situations it will climb hills easier and be quicker off the line.
Now, if only I could mod a HF79 to redline at 8000 RPM!
Thnx buddy but I already have fake mikuni from ebay, ill think of somethinghttp://www.affordablegokarts.com/mm...ode=A&Product_Code=1812&Category_Code=MTRBK79
http://www.affordablegokarts.com/mm...ode=A&Product_Code=2324&Category_Code=MTRBK79
The two items listed are your best bet. I have run this carb setup and the 22mm and feel the one I listed performs the best.
Most of the tanks I bought came scratched and one was rusty on the inside.i just updated couple more forums here are the pictures of the fuel tank
View attachment 68496 View attachment 68497 View attachment 68498
