Predyno 99cc......the ultimate daily cruiser!
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
25
38
Ridin' inSane Diego, CA.
You might not have noticed the new Honda valve cover......it is much nicer than the stock Pred cover. The beauty of this cover is that instead of a hole in the cover for the rubber breather hose, this one has a welded on nipple.
The big difference is you don't have oil coming out from this area of the cover. No matter how well I sealed the hose where it goes into the valve cover (not sealed from the factory mind you), oil would somehow find it's way through and cause a little mess after time.
GearNut
5,104
11
38
San Diego, Kaliforgnia
Thank you for the additional photos of the intake manifold fitment and the great tip on the Honda valve cover. I wonder if the Honda cover will also fit on the new 79cc Preddys...
runnermike
936
Sanford, FL
I was just about to ask if the valve cover would fit the 79cc preddy, but looks like you answered that question. lol Where would one purchase a honda valve cover to fit the 79cc preddy?
Sry for the silly question but I am just now getting my feet wet in the world of 4 strokes.
Also, does it matter if the engine is mounted vertically or not? I will be mounting mine horizontally....
GearNut
5,104
11
38
They are made to be mounted horizontally. Members here have learned that they can also be mounted vertically for frame clearance issues or visual appeal... or both.
scotto-
Jun 3, 2010
6,505
25
38
Speaking of valve covers.......look at the new idler pulley made from a Noram clutch driver. Was riding home in the cold dark last night and the idler came off and threw the primary chain somehow.
I ran out of skateboard wheels, but have plenty of clutch drivers......problem solved ;)
kinda blurry....
Master-shake
315
texas
Yes I would like to know.I have aolder Schwinn crusier frame
my seat post tube measures 1.140 if it is undersized on the clamp
Well ok, and not to sound rude.
Last time i checked he didn't make these clamps for a living. and could not, via his employer. he also made these as a "one off" and he may or may not have the prints for it.
So knowing that, I would suggest you fabricate your own mount accounting for your bike, and its exact specifications or, buy someones bike that looks like the one you want.
scotto-
Jun 3, 2010
6,505
25
38
Do you sell this mount? I just got a 99 preator I would like to mount it like this.I have no access to Fab Tools
If I had these mounts to sell, I'd trade you a set for a 99cc Pred engine. Fortunately for you, my bud Steve found one more set and gave it to me for my next race build so there are still none available that I know of. Kinda like the 99cc preds.....gettin scarce. ;)
Sorry I can't help anyone out with these clamps.......they truly are bomb-proof. And then some.
scotto-
Jun 3, 2010
6,505
25
38
one more question i dont think you ever said this but what size sprockets are you using? teeth wise
You're right, I never did say what size sprockets I am using cuz it's top secret. The gear ratio is 12:1. Do you want too know what size sprockets I use with the jack shaft to get that ratio? Of course you do :D
Here is what I use, a cheetah 2-disc clutch w/13t driver to an agk 26t......then an 8t off the j-shaft to a 48t rear sprocket. It ain't rocket science, but it works for me.
I have one also,did you use a thicker key on the shaft along with the sleeve?.........Curt
Yes I did Curt.
.wee.
