bike will start(kinda) but will not accelerate. HELP!
so i just bought a new cns carb and my bike will not accelerate. when im riding and i let go of the clutch, the motor turns on but there is absolutely no power. my throttle will slightly rev the engine but it is very quiet and will not push the bike forward. ive tried putting the choke all the way down and putting it all the way up. nothing will work. my previous stock carb worked fine so i dont think the clutch is the problem. i am certain it is the carb because the bike is pretty new(less than 50 miles). any help would be greatly appreciated. thanks
I won't be able to help you much. I've never even seen a CNS carburetor.
But it sounds to me like your engine is not starting up at all. So you need to verify spark plus fuel in the carb. It's not all that hard to do.
But I'm wondering why you changed your carburetor after only fifty miles. That could offer us a clue. Was the bike not running before the carb change?
sounds like you're running on the idle jet and getting no fuel thru the main or slide is not opening
i was using the stock carb and the bike wouldn't idle. someone had a similar problem and said that their jet wasnt attached properly in the carb. i took my jet out on the old one and when i was tightening it, it broke off,so i got the cns carb(only 20 bucks). it feels like i am not getting enough fuel to the engine? i have no idea but it definitely has something to do with this new carb.
first, take off air filter and look in carb to see if slide is going up when throttle is turned - if not, look at cable to find out why
if slide is working, then check fuel flow thru bowl and up main jet
Good thing crassius got in on this thread; I would not have known these things.
I'll keep watching and do let us know more as you go along.
