Trey
$50 Cruiser
GearNut- I believe I've mentioned to you that my bike is up and running!
To update here, at 5,500' I had to turn the air/fuel mixture screw out 3 full turns. There was a lag in the engine between say 3mph and 10mph, it was being starved. That problem has nearly gone away. I intend to experiement a little more to dial it in, but so far I could'nt ask for more. It is possible that re-jetting the carb would be an overall improvement...
. I just put on a NT Speed Carb yesterday and the bike ran great during a quick test run (FYI -only had half an extended exhaust pipe and no muffler) Then today I went for a ride (now with about 10 inches of an exhaust pipe left because the weld wasn't done correctly due to the metal constantly burning through and thinning out) and for a couple min I couldn't accelerate past the low end. When reaching top end the engine would want to die, the more gas I gave it the faster it would want to die. Well after a couple min it ran fine until I reached my destination. Upon returning to my home the same thing happened but hasn't gone away. So far I've checked for blockage, leaks, opened gas cap, checked the throttle linkage and the float isn't stuck but that's as far as I got and still no change. Oh yeah and I've run the bike b4 several times with the exhaust as it is now(with the stock carb) and no issues I haven't checked the forum completely due to lack of time so I apologize if there's already a thread about this and thank you very much for your time and thank you everyone, especially the most dedicated,
for making this site possible. If it wasnt for this resource I think there would be a #!*$load of chinagirl 2strokes pilling up in landfills everywhere....Thanks
