Actually I think the TAV would probably be a good set-up with this engine, my 212cc on the other hand was smokin the belts faster than I could replace them. This clutch set-up is a bit cheaper than the TAV unless you get it from ebay or the likes.Scotto, did you feel the 99cc wouldnt have enough power to use a TAV? I wonder because that looks like an expensive alternative (clutch)
Well I'll tell ya Dan, this engine is so economical that it runs on the smell of an oily rag. On the other hand, the catch can is going to be a rather unique aluminum one hand made by me. Unless I use it for the new and improved Slant that's finally on the way.Hmmm....
The seat post tube doubles as the oil catch can and breather.
Great idea! It makes me a little concerned about oily balls though...
I am still trying to figure out how you are getting fuel to the carb from the cylinder head breather though. That's an odd one for sure!
Ya know Greg, I would love to ditch the big fugly shroud and the only thing that keeps me from doing so is I'm going to be tuging on the thing everyday and my right rotator cuff is on the blink.Yea man, nice seat mod, great idea! She looks better without the big honkin' shroud, ever think of switching to rope like Jeff does? Could take the rest of the fins off
Almost sounded like you could hear the the rocker arms rattling, but it is more than likely something else making a rattling noise. Did you change out the exhaust pipe or is that before you made the one you are going to use?
I still need to make the exhaust, the gas tank, rear jack shaft disc brake and install the catch can and throttle cable. I'm working on the gas tank right now, i'll upload pics this evening cuz i've got some errands to run........Almost sounded like you could hear the the rocker arms rattling, but it is more than likely something else making a rattling noise. Did you change out the exhaust pipe or is that before you made the one you are going to use?
Yeah I know, huh......6,200+ rpm on the near stock engine with no load could be fatal.pipe looks clinton-est. square intake looks nascar. dont throw that rod bro!
The rear wheel is not out of true, it's out of balance.......it's true as an arrow.Badass "quick tank" method, love that.
You should add rear tire truing to your list, it looked like it wanted to jump out of the stand there.
Keep up the good work man.
