The KIP tensioner adds a quarter inch to the space between the clutch cover and the motor. So you get longer screws and a longer engagement pin. BUT the pin is ever so slightly too long so that the plate (when screwed down all the way) pushes the pin into the motor. I don't know if that's what the process is but the result is that the back wheel spins like I'm pulling the clutch in UNlESS I loosen the clutch screws. These are the washers.
AHAH! it's the disengager shaft. The Clutch cover forces it in.
