Ditto:Sorry, But I don't agree with leaning the engine, grinding gear teeth, or any other adaptation that try's to solve an alignment issue. The engine MUST be mounted straight and SOLID in the frame, It's made to go in this way. If the chain is not hitting the rear sprocket correctly, and the engine is in straight, then it's a REAR SPROCKET ALIGNMENT issue, not a motor mount or drive gear problem. I've had to spacer out, (or in,) many, many rag jointed sprockets to get the alignment right, Sometimes spending HOURS on it to get it right. (put it on, take it off, put it on, ect.)
The engine sits straight in the frame. The rear sprocket is supposed to sit straight on the wheel if you do it right. The only problem after that is spacing the rear sprocket(in or out,) to be IN LINE with the drive gear. This is the hardest part of the build, I know cause I've done 60 (or more,) of them. It takes time and patience to get a rag joint right. And thats just one more reason I use adapters whenever possible.
fatdaddy.
P.S. I've cut out and used the thin part of car tire sidewall to use as extra spacer to go out with it. Sometimes all ya need is a little. I've also cut thinner a stock spacer rubber to go IN with it. Cause sometimes all ya need is a little.
There are exceptions to the "mount it centered" rule. Some frame/rear wheel designs require the engine to be offset from center. The Nirve Switchblade and Schwinn choppers are examples and there are others that need the offset to allow the chain to clear the wide rear tire/wheel. Anywhere from 1/2 to 1" offset may be needed but even still the engine must sit straight with no angle viewed from the top down and the drive sprocket must be perfectly aligned with the rear, driven sprocket. This will usually require custom engine mounts.Side with 2 door, your ideas are cary sounding.
What about an axle mounted on the seat tube, like the jackshaft,but with another sprocket to drive the wheel to act like an offset, cuz that's all you need right?![]()
I totally agree with EVERYTHING you said in both posts. And although I've only built 10 of the OCC's, and one Jesse James, The engine, even off to the side, was straight in line with the frame and sprocket. And heck, that cheap chinese chain will knock the rough edges off any sprocket.There are exceptions to the "mount it centered" rule. Some frame/rear wheel designs require the engine to be offset from center. The Nirve Switchblade and Schwinn choppers are examples and there are others that need the offset to allow the chain to clear the wide rear tire/wheel. Anywhere from 1/2 to 1" offset may be needed but even still the engine must sit straight with no angle viewed from the top down and the drive sprocket must be perfectly aligned with the rear, driven sprocket. This will usually require custom engine mounts.
The jackshaft idea has been tried with varying results.
Thats OK Mitch, I don't want to spend $200 or better on a SPB jackshaft/shift kit to solve a little alignment problem. Besides, the SBP kit, which allows you to shift gears, is not legal in California.Side with 2 door, your ideas are cary sounding.
Just putting it out there, my engine has always leaned just a tiny bit to the left by probably not more than a degree (mind you, it never moves and I can't make it move by pushing it hard) and I've never had a problem in 2000 miles. No abnormal wear, no chain hopping, no noises. I also spent a long time making sure my alignment was perfect when I got a sprocket adapter.
I'm not saying go and lean the engine on purpose, it's not supposed to, but also there are situations where it isn't a huge problem. Good alignment is the top priority, but sometimes there are situations where a build just isn't going to be perfect, or you need a workaround.
Hey fatdaddy - Yeah, I read all those post b/w you and the Sarge, back when he was first getting into it. He figured out a pretty genious design, but didn't figure out paypal. ha! So you're using the Howard version now? I have two Cranbrooks and one has hub diameter of 1.507 and the other has diameter of 1.527. Would the Howard version work on either hub ya think? And one sort of related question - should the engine be tilted SLIGHTLY to the left on the frame in order to receive the chain more smoothly? Have you heard of this before? My grinding / occasional pop sound might not be sprocket alignment, but rather, I need to make sure both sprockets are on the same plane?
No, the engine tilt / centered issue was very helpful for me. I bought a laser level today to make sure the sprocket is perpendicular to the ground. Sucks being a perfectionist. At least I justified a trip to the hardware store with my other bike though. I will take your and Tom's advice and keep the engine dead center and fool with the rear sprocket. Heck,its a long winter. But gotta admit there seems to be some logic to pilot's reasoning. Thanks everyone. And let me know if you ever run across another one of the Sarge's mounts.
I hear you, but these engines are not Honda's, you know? If I was riding a Honda instead of this huffy with a China doll.... I think this wouldn't be an issue....also wouldn't be as much fun!........sprockets.....!@#$
Can you guys check out my other thread? motor won't run or stay running.
I'll share my plans for an adjustable pressure exhaust with if you help me out.
It came today. But now the clutch acts like it's pulled in when I tighten the plate on. As in, it's pushing the 8mm pin into the engine, thus freeing the back wheel, causing no compression. I know I didn't lose the woodruff key because when I back it out or take it off there's compression.
I have installed 3 washers on the 3 clutch cover screws, so 1 per screw. This helps, but the plate is still engaging the pin when the clutch is out so it rolls a little. I don't know what to do. It's not right to drive it like that. I have been out there an hour and a half sawing screws, tweaking things bleh bleh bleh. I am ALMOST at my wit's end here.
This all started when my dad told me to oil the chain. I did. And then it slackened almost an inch, Threw the original tensioner, stripped the screws and then I ordered this one. And now I am here.
