Man, some of that was a tough read. Let's get back to the question of how to make the sport grow.
I am new here, but not new to racing. I plan to attend the next Grange race to watch, but I can already make some observations after reading several race threads. Other posters have mentioned some of it, but I did not take notes while reading so I can't reference the posts by name.
Since this is not racing against the clock like Solo1, or the Peak - classes will always be necessary & contentious. Adding layers of rules does not fix it, just adds to the cost to compete. Let's keep NHRA / NASA / NASCAR etc. out of this while we can.
Heats.
A "heat" is usually a short series of laps to sort out competitors by capability - both rider & machine. Since it is obvious that many of the machines & riders are getting beat up qualifying for an event they all will run I would suggest shorter heats.
As someone already stated, motocross, BMX etc. runs heats to eliminate slower riders from the field. This can be a safety issue as much as anything. But it looks like the small numbers of competitors will mean that all the riders wind up in the main. Still, using short heats will allow for better grid sorting for a main.
I would propose 5 lap "heats". Two of them. The top 4 or 5 finishers from Heat #1 can sit out heat # 2. They are the front of the grid for the main. The balance of the grid is the second heat in order of finish. This will keep the slower riders out of the way, but allow someone with skill to advance. Rather than running 24 laps before the main, riders & machines would run a max of 10 laps.
This would also leave more room in the day to further divide classes if necessary. If you manage to grow the sport, and the field gets big enough- you can begin to drop the 5 slowest riders from the second heat to control the size of the field in the main.
I see timing discussed. Chip timing foot races & bicycle races is the standard anymore. I have run enough races with a chip in my shoelaces to trust them - they can pick you out of a pack of runners 5 abreast. There are arch style timing units that will pick up a bike rider @ 75 mph. Perhaps one of these systems could be used to improve timing?
Some riders will always rise to the top. Adjusting classes by displacement / power are generally used to "level the field", but occasionally there will be a rider so good (or well financed) that it seems like you can only get a 2nd place. Try to avoid tweaking the rules for "that guy" - after the challenge is gone he will eventually switch classes or sports because he is bored with first place anyway.
Now let's look past what is already there in the sport. Someone mentioned a dirt track / flat track event. Sounds fun. How about a version of Supermoto? Is there room for that at any of the tracks in use now? A dirt or Supermoto event with a bigger field, just a straight up race with no heats might be the ticket for summertime when the temperature is an issue.
One more thing that I will throw out, then I will get off my soapbox:
Claiming class for unlimited racers.
In all my years of racing, I have never see a better way to tone down the over the top, purpose built entries. For those of you unfamiliar with the concept, it goes like this. Race entries are built to a value limit. If you enter a $3000 claiming class, you are saying that you have no more than 3k in the vehicle. At the end of the race, the winner can be compelled to sell his racer to anybody that was racing against him for the $3000. Winning a 50 buck trophy or $250 purse with a 10k value "my dick is bigger" machine is no longer as big a thrill...
B.
