"Another easy mod is remove the sparkplug and using a dremel cut the ground electrode to a v shape this uncovers the electrodes so the flame curnel is exposed better to the fuel mixture which permits better combustion of the fuel."
That is a disaster waiting to happen...if you bend the electrode out enough on a plug to "dremel a V groove" and bend it back to gap it, you may as well just break it off, throw it in the spark plug hole and try to start your engine!
That's not going to improve the performance of these engines one bit.
what is a ground electrode?
The part of your plug you don't want to bend back and forth.
could i make a boost bottle out of a large sealed soda can? how do i hook it up?
Boost bottles have to be rigid. They only help if they are perfectly set up, your carb is perfectly set up, and then it has been the experience of many her ethat they are a waste of time and money.
doesn't the exhaust need a little resistance? i hear its bad for the motor if its just running into thin air.
They don't NEED backpressure, but without it, they don't like to run at anything other than wide open and very rich.
would ngk snowmobile spark plug wire be a good upgrade? i've got the best kind
Definitely.
thanks guys
