Chapter7slave
Hi gang, I have a question about triple tree forks. They come either with a threaded or non threaded headset. Which is better and why? And where can I get a good one with disc brake tabs built in? Thanks.
The main difference is the stem. There's 2 types of stems. Threadless are stronger. The threaded have a weaker connection, but are still strong enough for most MBs.
For most people it comes down to whether they want to change their stem or not.
I think threaded have a little more adjustability.
Ummm, the main difference is the headset.......the stem is the other difference. One is not neccesarily stronger than the other, but the non-threaded tend to stay put, once tightened down. The threadless are just as adjustable, if not more so than threaded. If you want to heighten the stem (raise the handlebars) you just leave the steer tube longer and add spacers. You can also flip-flop most threadless stems for even more adjustability.
I'm not sure I understand what you mean by headset. Headset, is the bearings and races that fit between the frame and steerer tube.
Are you referring to the frame head, as the headset?
I use threaded and threadless headsets on my bikes. I prefer the threadless for mountain biking, as the handlebars stay in alignment with the forks better (they don't twist). In my opinion, the threaded headset also requires more frequent adjustment. However, the threaded headset on my motorbike has worked fine.
