I agree with Alf.
Even Al beverage cans cut for shim stock get hammered and become worthless in many applicatons.
Best
rc
That's why Aluminum is used in gaskets, you can crushed it.
I agree with Alf.
Best
rc
Thanks I will change the spark plug. I got it to fit. What I did was to shove metal flashing in the tiny gaps. It really was tiny. My arms are sore from shoving it so tight . LOL Its not going anywhere. Not my idea someone here mentioned it and it sounded like what I needed to do. I will take a pic later on. I did shove the bottom down a bit and it looks good. Somehow I did it with just 2 curse words and no dinging up the bike. Please don't tell me it wasn't a good idea. I don't think my arms and take it. LOLWell, I like the colored tape better, but as Joe said, the pvc just won't do.
The pic with the black tape is quite good.
Skooch the back of the motor down just a tad, and lift the front equally, and your carb will sit just perfect! Perfect level is best, but they actually will function ok if a few degrees off.
You may un-fasten the four nuts on top of the cylinder head, remove the head, and reverse it so the plug sticks back to the rear, if you need more clearance for it. It probably does not make a lot of difference in operation.
You should buy a replacement NGK sparkplug and set that china plug aside.
Good progress!
rc
Was the mount slightly loose before you shoved the metal in there, and then you tightened it?Thanks I will change the spark plug. I got it to fit. What I did was to shove metal flashing in the tiny gaps. It really was tiny. My arms are sore from shoving it so tight . LOL Its not going anywhere. Not my idea someone here mentioned it and it sounded like what I needed to do. I will take a pic later on. I did shove the bottom down a bit and it looks good. Somehow I did it with just 2 curse words and no dinging up the bike. Please don't tell me it wasn't a good idea. I don't think my arms and take it. LOL![]()
No I should have been more clearer the mount was loose before I put the metal flashing in. I shove what ever I could in and then tightened it. Im sure if I stand on it it won't move but I'm not going to try that. Its good ...thanks.Was the mount slightly loose before you shoved the metal in there, and then you tightened it?
If you shoved it in there with the mount already tight, there's not gonna be enough pressure on them they're prolly gonna work back out.
I AM having fun doing this! I was the girl in HS that like the wood shop a lot better then the sewing classes. LOL I work 12 hour days so I have been doing one thing a night to get it set up. Hopefully by next week I'll be rolling. Can't wait!!Oh my!
Golly, what an adventure you have undertaken!
I certainly hope you are appreciating every bit of this in entertainment value, in addition to the learning part. And that's not to mention when you begin tuning it, and actually riding!
Best
rc
