Accelerates very well from a dead start. The engine has lots of low end torque. Also the torque converter has lots of multiplication right off idle.That is awfully tall gearing.....how does it take off from dead stop?
I've been running mine with 10.18:1 gearing and front pulley engagement of 3,300rpm......from a dead stop the front wheel loves to leave the groundAccelerates very well from a dead start. The engine has lots of low end torque. Also the torque converter has lots of multiplication right off idle.
With the 10:48 it took off about the same, but midrange was stronger. It's very smooth and manageable and maybe goes 35 at whatever the gov. rpm is.
It's just a huge wide engine to get used to. I want to GPS it to see what it's doing.
Thanks, I have a Garmin, but the batts were dead.If you want a Gps try your local bicycle shop
That must be a rush!I've been running mine with 10.18:1 gearing and front pulley engagement of 3,300rpm......from a dead stop the front wheel loves to leave the ground
http://en.wikipedia.org/wiki/Continuously_variable_transmissionCan I please have a link to the torque converter? is it the entire transmission or just the clutch? I am going to install a 99cc predator.
just search ebay for go-kart torque converters. you will find the $129 ones in either 3/4" or 1" shaft size, and 6" or 7" driven pullies. 7" has a torqier ratio but the larger driven does not fit in the plastic cover.yank, thanks for the link, but i was asking for a link to where they bought it from. if thats the whole transmission, thats a lot cheaper than the transmission I was looking at. the op said he got it for 129. That would bring my build way under 300 bucks. So again I ask. oldmotorbike, could you please link to where you bought your transmission?
You would have to sleeve the 5/8" shaft and I'm not so sure that would be a good idea as the driver mounts on less than 1/2" on the end of the driveshaft.the 99cc has a 5/8 shaft.
One other thing to think about is the power a torque converter will rob from a 3hp, 99cc engine. You'ld be suprised.yeah, I wasnt considering installing a predator when the 212 was on sale. been thinking about it for a little while, but only recently decided to do it for sure. a torque converter tranny is a lot cheaper than the tranny i was gonna go with originally, so that gives me all the more reason to do it. besides, i doubt a 212 would even fit in my frame. its a cranbrook, and from seeing pictures of another members build, it barely has room for the 99cc. I am gonna take the 99cc sticker off and then cover the engine markings with jb weld or some other type of putty, maybe exhaust putty, then paint over with bbq paint to seal it. if a cop asks whats with the paint, I just have to say i started to paint the engine then changed my mind. that simple.
