fugit
i read just fine but obviously you don't - seeing as you took my sound advice, took it out of context, twisted my question and then replied with your ridiculous txt-tlk post.
Look in the mirror my friend.
i wub u 2 mikey!
Everyone else![]()
SO I think I am going to mount front brake on left under clutch. I use clutch more here because of the hills. I will use front break only in emergency anyway. The rear caliper is on right side and using it with coasters works good if you want to slide stop in emergency. Adding front will stop that and maybe stop quicker we'll see.
My idea is based on "what if" I have a brake failure? If I have double brake levers on right and they fail I am stuck with my coasters. If I have two calipers on different sides ( front left, rear right) and any one of them fail I still have one and the coaster brakes. If coasters fail I still have both calipers on either side. I will set the front brake to grab lightly so not to skid on front tire becasue there is alot of sand around here. I like the odds better this way.
One thing that I did decide as a result of this discussion is to mount the front brake lever so i can grab it with my thumb or between thumb and pointer finger. 45 or so degree's but towards rider. Since it is a short lever it seems that will work well and if I need it it will be like grabbing onto something in a grip rather then pulling with 4 fingers. I might use it more too that way.
And this is for just this bike anyway(Or any bike I ride). I will try the dual brake lever on the right for another bike I am building because it seems the more experienced riders like them and they work well.
