What's your most desirable accessory for a China Girl Motorized Bicycle?
biknut
I'm thinking a hub adapter is probably at the top of most peoples list, mine anyway.
After that probably motor mounts would come next.
What do you think?
Re: What's your most desirable accessory for a China Girl?
I'd have to agree with ya biknut, a hub adapter is the most desired right now. I haven't had any problems yet with the ragjoint but i do want something better than just a little bit of chinese rubber and crappy chinese bolts n' nuts.
For me it would be a custom gas tank by far! One that holds at least a gallon of gas and actually looks nice with the bike.
A shelf to put it on when I put on a 4 stroke LOL
I feel you. I'm not using my smoker nearly as much any more. But I'm thinking about taking hill climbing this weekend. See how it does.
a high compression head, dual carbs, nitrous and the ability to shift through 5 gears.
I would like to buy a hub adapter from one of our MB vendors.
rc
For me it was the Sick petcock that doesn't leak.
Dripping gas on a hot motor is a good way to end your life.
lock tight is no.1,hub adapter,bearing chain tensioner,clutch lever then charger/generator light system.
Reliability. It's all I ask of any machine I own. With my China Girl powered bikes, so far, so good. :)
A padded chain and some loops screwed into the block. So I can wear it around my neck.
In Soviet Russia, engine accessorizes you :D
Nitrous is no good unless you have a way to dump extra fuel with it. Nitrous is an oxidizer.without more fuel the cylinder temps will sky rocket because you just introduced a lean condition.
yes, i know that. I had a drag car with a 175 h.p. plate nitrous set up on it.
yes, you need more fuel to add with the nitrous to keep it from leaning out and that's why a real nitrous set up has a fuel solenoid, a nitrous solenoid, and 2 fuel pumps.
been around it all my life.
Ok. Some people think nitrous is some magical power adder like a pixie dust spreader on the tilt-a-whirl.
1.Better mounting hardware
2.Better intake gasket
3.Better spark plug wire & NGK cap
4.Better NGK spark plug
5.Better tuned carb. by rejetting smaller
6.Better free flowing exhaust
These are the first things I address on the China Girls.
IMHO the better reliability that Tom spoke of above can be much improved by making the #1-4 changes right out of the box, #5 & #6 helps in the power and better speed area.
I know not everything I listed here is an accessory but these are all good things to do IMO for multiple reasons
Peace, Map
