What's your most desirable accessory for a China Girl Motorized Bicycle?
Discussion in 'Motorized Bicycle General Discussion' started by biknut, Mar 14, 2012.
  1. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    I'm thinking a hub adapter is probably at the top of most peoples list, mine anyway.
    After that probably motor mounts would come next.
    What do you think?
  2. James912
    James912 Member
    Apr 12, 2011
    586
    Re: What's your most desirable accessory for a China Girl?
    I'd have to agree with ya biknut, a hub adapter is the most desired right now. I haven't had any problems yet with the ragjoint but i do want something better than just a little bit of chinese rubber and crappy chinese bolts n' nuts.
  3. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    Hub joint then a springer to smooth out the ride
  4. Texhun
    Texhun New Member
    Aug 2, 2011
    322
    For me it would be a custom gas tank by far! One that holds at least a gallon of gas and actually looks nice with the bike.
  5. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Fuel mix :>)
  6. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    A shelf to put it on when I put on a 4 stroke LOL
  7. moonerdizzle
    Jun 28, 2009
    874
    I feel you. I'm not using my smoker nearly as much any more. But I'm thinking about taking hill climbing this weekend. See how it does.
  8. dragray
    dragray New Member
    Mar 10, 2012
    278
    a high compression head, dual carbs, nitrous and the ability to shift through 5 gears.
  9. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    I would like to buy a hub adapter from one of our MB vendors.
    rc
  10. YoungRatRod
    YoungRatRod New Member
    Oct 19, 2011
    157
    well wayne, I can help ya there :)
  11. YoungRatRod
    Oct 19, 2011
    157
    and I just want a custom exhaust or a trike conversion kit
  12. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    For me it was the Sick petcock that doesn't leak.
    Dripping gas on a hot motor is a good way to end your life.
  13. robbomberbomyea
    robbomberbomyea New Member
    Dec 10, 2011
    267
    lock tight is no.1,hub adapter,bearing chain tensioner,clutch lever then charger/generator light system.
  14. Dirt Road Cowboy
    Sep 18, 2011
    296
    MO' POWER!!! rotfl
  15. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Reliability. It's all I ask of any machine I own. With my China Girl powered bikes, so far, so good. :)
  16. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    A padded chain and some loops screwed into the block. So I can wear it around my neck.
    In Soviet Russia, engine accessorizes you :D
  17. moonerdizzle
    Jun 28, 2009
    874
    Nitrous is no good unless you have a way to dump extra fuel with it. Nitrous is an oxidizer.without more fuel the cylinder temps will sky rocket because you just introduced a lean condition.
  18. dragray
    dragray New Member
    Mar 10, 2012
    278
    yes, i know that. I had a drag car with a 175 h.p. plate nitrous set up on it.
    yes, you need more fuel to add with the nitrous to keep it from leaning out and that's why a real nitrous set up has a fuel solenoid, a nitrous solenoid, and 2 fuel pumps.
    been around it all my life.
  19. moonerdizzle
    Jun 28, 2009
    874
    Ok. Some people think nitrous is some magical power adder like a pixie dust spreader on the tilt-a-whirl.
  20. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    1.Better mounting hardware
    2.Better intake gasket
    3.Better spark plug wire & NGK cap
    4.Better NGK spark plug
    5.Better tuned carb. by rejetting smaller
    6.Better free flowing exhaust
    These are the first things I address on the China Girls.
    IMHO the better reliability that Tom spoke of above can be much improved by making the #1-4 changes right out of the box, #5 & #6 helps in the power and better speed area.
    I know not everything I listed here is an accessory but these are all good things to do IMO for multiple reasons
    Peace, Map
